JD 175 Hydro neutral and brake adjustment
   / JD 175 Hydro neutral and brake adjustment #1
diggerjim
Sothern Illinois
Yanmar 2220D
I just (this saturday ) picked up a used JD 175 Hydro cheap at a garage sale. It runs and mows good but the neutral position is a little tricky, and it jumps forward when in neutral and the brake pedal has no effect so I assume they need adjusting. I searched 100 pages in this forum but did not find any info regarding my problem. I also searched the web for a few hours with no particular help. Anyone have ideas? I will be buying a manual but I need to mow now..........grass is growing..........its raining.........etc.
   / JD 175 Hydro neutral and brake adjustment #2
I'm having same problem. Does anyone have the answer to this?
   / JD 175 Hydro neutral and brake adjustment #3
I am in need of an answer to this question as well
   / JD 175 Hydro neutral and brake adjustment #4
If you follow the control level down, there are some nuts you can adjust. I forget exactly, but you can adjust it. Private message me your email and I can send you a copy of the instructions I have.
   / JD 175 Hydro neutral and brake adjustment #6
Hey Diggerjim and beenhere: thanks beenthee.I found out about how to adj brakes by following the linkage on the parts breakdown the 5/16 th nut (1/2 wrench size 1&1/2 turns solved the problem) going clockwise on the nut. Hey diggerjim I would start off with that adjuster and check the brake lock adjustment. Hope I haven't confused you Guys. If so get back to me.
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
