photos of Iseki FEL
   / photos of Iseki FEL #1
morton2
Can anyone provide any pictures of a Front end loader for an Iseki TA550 or similar tractor.
My Tractor has a full cab with mounts underneath the cab (vertical flat plates with 4 threaded holes).
I am intending to fabricate my own loader. I need some point to start with regard to mounts, gussets etc & where to mount these.
Arms, bucket, hydraulics aren`t too much of a problem, although where to get the feed & return for the hydraulics is a bit issue at the moment but I should be able to find the delivery & return.
thanks in advance for anyone who can help me.
Peter
   / photos of Iseki FEL #2
Howdi, I thought I replied to this question. Guess not. I have a TA240 and am told it has the same frame as a TA 250 and 260. It uses a Koyker 125 FEL. Yours may be larger but I bet the mounting is the same. Still need the photos? I can send you the drawing from when I assembled my FEL if it would help.
MM
MM
Hi Yomax4,
This would have to be the latest reply to your reply ever. If you could email me the photos of your loader that would be great. I`ve actually atarted my loader finally & would love to see where I have gone wrong or right.
Cheers Peter
   / photos of Iseki FEL #4
Peter
Are you still in need of info for your FEL? If so, I recently bought a dead Bolens G154 that has a FEL as a donor for my 154. I can take pictures of everything you'll need as I take this loader off and refinish/rebuild it, and replace it on my Bolens.
   / photos of Iseki FEL #5
Send a Fax # and I can fax you the install instructions from my FEL. It shows a ghost image of how it all goes together. Or I may be able to scan part of it and send it in an e-mail.
Thanks.
MM
Toro Workman GTX Golf Cart (A50121)
Toro Workman GTX...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
1013 (A51573)
1013 (A51573)
2023 Bobcat T66 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T66...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
