Simple plumbing question re: teflon tape
   / Simple plumbing question re: teflon tape #11
I disagree, in part, with all answers given.;)
larry
   / Simple plumbing question re: teflon tape #12
JDeereman said:
Thanks to all who replied. from your collective suggestions, i think i see where i may have been going wrong and not getting really great results. i'll go back and try again armed with this info. thanks!
Theo
Don't hog all the experience to yourself :). Tell us where you went wrong and what you did different. Did your results improve?
We all want to learn from your experience so we don't have to make all the mistakes ourselves.
For one thing, it never occurred to me that there was a wider teflon tape available for larger diameter pipes. i've been using 1/2 inch where i apparently should have been using 3/4". i will have to look for it. i've also been using 2 wraps max where i probably should have been using 3 wraps. but tightening is also a mystery to me. seems that where fittings finally line up, they are always either too loose and leak or it would take overtightening to get one more full turn. this usually means i need to start all over again and use more or less tape but often with no better results.
Theo
   / Simple plumbing question re: teflon tape #15
Theo
If a fitting is a little too loose at lineup, take it apart and clean off the teflon scraps. Then put moly anti seize grease on the male, assemble, and tighten 1 turn beyond the too loose line up point. Remove, clean, rewrap teflon, and assemble to the line up tight point.
larry
   / Simple plumbing question re: teflon tape #16
I realize you are probably speaking of conventional home water line plumbing, but thought it might be worth clarifying;
Tractor hydraulic plumbing should not use teflon tape on the threads. Instead use the paste with teflon in the mix and be sure it is rated for hydraulic oils and pressures.
Also; when using teflon tape on water pipes, the direction the tape is wrapped onto the threads matters!!
One more thing; gas pipes use a yellow teflon tape and water pipes use white teflon tape.
   / Simple plumbing question re: teflon tape #17
SPYDERLK said:
... Then put moly anti seize grease on the male, assemble, and ...
Just a precaution, if you're working with fittings on an oxygen tank or lines (e.g., for an oxy/acetylene torch), don't use any oil or grease.
   / Simple plumbing question re: teflon tape #18
The teflon tape varies in thickness. The yellow "gas" tape is supposed to be double density or twice as thick as the white stuff. But I use Oatey brand, and their white tape seems to be thicker than the cheap white tape and about the same thickness as their yellow gas tape. The thicker tape is much easier to work with (it doesn't twist as much and it doesn't stick to everything as readily).
The number of wraps depends on the tape which varies in thickness. I prefer the thicker tape, so I usually give it two wraps.
The tape should be wrapped around the male threads in the same direction as you turn the female part (so it doesn't tend to unwrap when you thread the female part on).
There's a controversy relating to using tape for gas fittings. Some argue that bits of the tape can plug the orifice of a gas fixture, which might be the reason some only use dope on gas lines.
   / Simple plumbing question re: teflon tape #19
ampsucker said:
anybody else prefer pipe dope over the tape?
i bought a decent size bottle of the white pipe dope/putty and have never looked back. on the can it says it is good for water, air, natural gas, propane, hot/cold, just about anything except strong oxidizers.
whenever i've watched a plumber, they almost always seem to use the dope and not too many choose the tape option.
just curious if this is the norm or if there is some good reason to go with one over the other.
amp
I've had mixed results with tape and mostly poor results with tape when used on water lines. I have followed the gist of most suggestions here so far and experimented with more and less tape wraps. I now use tape primarily for air lines and sometimes brass fittings. For most of the remainder of my pipe fit-up I use "Rector Seal" brand pipe dope. I've never had a leak with the Rector Seal.
   / Simple plumbing question re: teflon tape #20
I think the reason the pros use the dope is because it's just easier and quicker.
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2016 WACKER NEUSON LTV6 PORTABLE LIGHT TOWER (A51247)
2016 WACKER NEUSON...
ATLAS 10 1/2' DISC HARROW (A51247)
ATLAS 10 1/2' DISC...
8" & 10" I BEAMS UP TO 102" LONG (A51247)
8" & 10" I BEAMS...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
