I do not disagree with those who say this. i have heard it and read it many times as well. but why then can't we just use a little oil or grease when connecting threaded fittings (other than in potable water systems of course)? if all we really need is a temporary lubricant during tightening and the threads are supposed to seal perfectly against themselves, why doesn't this approach ever seem to work?
Theo
Theo
Seems to defeat the whole point and purpose of using threaded fittings in the first place, doesn't it? would such a system still meet the plumbing code? are malleable or cast iron fittings still good if back welded?In some types of service threaded connections are not considered secure until they are back welded.![]()
All this teflon talk but... no one mentioned the fact that tapered threads act like a wedge when tightened. Teflon tape lubricates the threads very well so the force required to over tighten the joint may go unnoticed resulting in cracking the female fitting be it brass, iron, steel, or whatever.
If you have much experience with pipe dope then be advised tightening a joint to the same "torque" when using teflon can crack the female fitting. You may not notice the crack (at first) or it may not appear until the joint heat cycles a few times.
My yellow (gas) teflon tape IS thicker. I have installation instructions accompanying equipment that FORBID the use of teflon and void the warranty if it is used. One itsy bitsy piece of teflon in the wrong place is not a good thing for a plasma cutter, for example.
Pat
