Older Murray lawn tractor
   / Older Murray lawn tractor #1
shortlid
Derry, NH
OK, neighbors just retired there 1999 Murry lawn tractor. I have helped them with it so they want to give it to me! I have a VERY steep lawn and use a walk behind now for my acre of land, how can I make the tractor more stable on the grades?:confused:
If I can remember corectly this mower has a twin blade deck, and a single cyl. vertical shaft splash lube l-head B&S engine. Has a 8 speed shift on the fly transmision. The tires even in the rear seem small and the tractor seems low to the ground which is good.
   / Older Murray lawn tractor #3
I had a older Murry mower and put chains on it. It made it safer on the hills for me.
Go to know do they make chains for the small 18" rear tires?:confused: Would weight on the front help as well.:confused:
I have seen the guys that race these things lengthen the axle and make the track wider. How hard is that to do with it?
   / Older Murray lawn tractor #6
I have an '02 Murray with HST. I use it on all the steep hills I have, 20 degrees plus (one is over 25, but tilt meter doesn't go past 25) - I mow across - sit on the fender out rigger style. I go slow and been doing it for 6 years. Never have come close to rolling even though it feels like it sometimes
Vertical on the hills has caused many pucker moments.
Now, without HST, I might be more nervous
   / Older Murray lawn tractor #9
The smaller stance tires are actually going to help you on the grades. I would use a good new set of Carlisle turf tires on both front and rear, and add rear wheel weights and/or chains, and of course never take it out if the grass is wet. However if is is one of the older splash lubed engines that did not have a pressurized oil system, it isn't going to last very long running it on steep slopes. But the lower the center of gravity, the more stable the tractor will be.
-Fordlords-
Thanks for the info. Guess if I do use it on the onclines I should not shift on a slope. Will see what kind of shape the tires are in.;)
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2001 INTERNATIONAL 8100 WATER TRUCK (A53843)
2001 INTERNATIONAL...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
