PTO Shaft question
   / PTO Shaft question #1
topshop
Northeastern Michigan
I have a NH TC34DA and am about to buy a King Kutter 60-inch tiller. Does anyone know if I will have to shorten the PTO shaft on the tiller?
   / PTO Shaft question #2
When you hook it up, you will know.
Bob
   / PTO Shaft question #3
Bob
If you can't hook it up, you will know for sure. Seriously, there should be a minimum of 6" of overlap at the longest length and sufficient clearance to connect and disconnect the shaft at the closest point.
   / PTO Shaft question #4
You will definitely have to shorten it. I bought that same tiller for my tc33da much the same tractor. Do not forget to put the oil in the tiller,top and side filler holes,it did not take as much as the instruction book said .
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2007 International 4300 Cab and Chassis Truck (A51692)
2007 International...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A51692)
2003 Chevrolet...
Deere 700K LGP (A50123)
Deere 700K LGP...
