I have 5 acres with 600+ ft of stream frontage. I plan to do loader work, grading, mowing, bush-hogging, and move a few logs around that get piled up after a flood. We are looking to buy another 10 to 20 acres and I would like to cut some hay. Both to sell and for the animals we will be feeding. I am currently leaning toward the 2330 but wanted your feedback on the two models. And if you think the 2330 will get the job done.
Aside from the obvious gain of 5 hp for the 2410, what do you all see as the advantages for the 2410 (class 4) over the 2330 (class 3), or, vice-versa. You gain 5 hp with the 2410 but you also gain weight. Weight can be good but in this case does the extra 5hp get "nullified" because of the added weight of the 2410? The 2410 is turbocharged, what are the advantages / disadvantages over the normally aspirated, and vice-versa? You get approximately an extra 1000 lbs of 3pt lft with the 2410. Do you see this as a big deal in my case?
Anything you can think of to throw in here to compare the two tractors I would be interested in hearing. I would be especially interested in people who have ridden on both of these machines.
TIA,
SouthernX
TIA,
SouthernX
