RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,902
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I second the notion about NOT using EP 90 gear oil. It's way too heavy to mix in properly and will likely leave some unburned carbon behind, if it doesn't gum things up first in not mixing properly.
If you happen to have some cheap or leftover transmission fluid, it can be added to diesel. TF is 5w oil and is sometimes a cut off the pipe stills that isn't captured from TF or lube oil and is diverted to the diesel pool. I had some leftover Mercon TF from when I had a Ford Ranger. Poured remaiins of a quart in my tractor tank and a whole unopened quart into the 240D tank.
Normally, you should use no additive for lubricity to ULSD. It isn't needed.
Ralph
Ralph
