Hoe'ing on a steep hill
   / Hoe'ing on a steep hill #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I have four acres, and the only flat areas on my property are the floors in my house. I try to do most of my digging uphill (tractor facing downhill, but I'm facing uphill while spun around, of course) whenever possible. When I'm digging downhill, it's just too easy to pick up the front end of the tractor or accidentally drag myself down the hill closer to the hole where I don't want to be.
I now need to do some digging on one of the steepest parts of my property. Fortunately, I have good access to do it all uphill, and am only digging here as a source for fill-dirt for elsewhere. It's hard to estimate, but I'm going to guess that the hill is about 30ー (pi/6 radians). Well, maybe. That's pretty steep. But, regardless, it's steep. So, my questions or wonderings are:
  • Where is the oil pump pickup in a BX24 engine? If it's at the rear of the pan, I'll be a bit worried about having the engine sitting there running pointing downhill (from the tractor's perspective).
  • It seems like trying to decrease the angle with the loader could be good in some ways, but it also seems that it could really be quite a strain on the loader as well to have the tractor high off the ground on a hill like this. Thoughts?
Thanks
   / Hoe'ing on a steep hill #2
have you considered in removing the loader so its not so tipsy ? when i mow the banks sideways , the loader makes its seem tippy even with loader close as possible to ground. when i removed the loader, it was so much better. Also the mower deck help to lower the center of gravity as well for better control. Have you had your tires loaded yet ? i feel its a must for those who have BX's with hills.:)
   / Hoe'ing on a steep hill #3
I don't know which end the oil pickup is on. Bit I wouldn't worry about strain on the loader. Doesn't seem like 1 inch or
1foot would make big difference. On my 23 if I pick up the front end when digging it creeps back down fairly quickly until the front tires touch. Like in about 10 or 15 minutes.
   / Hoe'ing on a steep hill #4
I always try to dig from the down hill side whenever possible. On the up hill side the hoe plus gravity wants to move the tractor too easily and I would think it would be even worst with a lighter tractor like the BX. Sounds like a pretty good slope you plan to work. Might even consider running a chain from the tractor to something like a truck hitch to keep you on top of the hill.
MarkV
My bx tractors must not know this = they perform great with unloaded tires.
If you've never used a BX with loaded tires, you don't really have a reference point to which to compare the unloaded performance. Since my tires aren't loaded, I can't comment on how it performs with them unloaded in comparison to having them loaded. I just know that there are times that I'd like a full-size excavator. :rolleyes:
   / Hoe'ing on a steep hill #7
Maybe his posterier provides sufficient ballast :)
   / Hoe'ing on a steep hill #8
I never planned on loading my BX23 rear tires... it's just that I was always getting flats which meant I'd have to stop to repair the flat... kind of reeks havoc with the schedule.
Anyway, I had the rears foamed filled which added 144 lbs to each tire... I couldn't be more pleased... no more flats, lowed my center of gravity and improved my backhoe digging.
   / Hoe'ing on a steep hill #9
how do they load the rears with foam? 144 lb's per tire? cost alot?
   / Hoe'ing on a steep hill #10
I delivered my two rear tires to a Farm and Commercial Tire shop. Both of my tires had previous unsuccessful repairs and would go flat overnight.
Anyway, they remove the valve core and drill a small vent hole in the tread 180 degrees from the valve stem.
They pump in expanding foam until it comes out of the vent hole that was just drilled. I had requested medium density fill...
Note, filled tires are not recommended for mowing because of the extra weight
After filling, they brand the tire with a hot iron with a label that says foamed filled, not for high speed use.
The tires need 24 hours to cure without a load, otherwise there will be a permanent flat spot if not allowed to cure.
I learned about foam filling here on TBN
The total cost was $375 for both... not cheap, but no more flats.
The tire shop also re-grooves and recaps on site. They told me to bring the tires back when they are worn out and they will recap at half the cost of new...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
10 Ft Fork extensions (A50322)
10 Ft Fork...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
