IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 15,802
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
I believe the lift capacities of the LA402 are greatly under rated.
I recently picked up (with the FEL) a 800lb backhoe with a 230lb operator and i was using a 100lb skid steer qa adapter on my B7800 LA402 (with counter weight). I really didn't think I was gonna be able to lift it, but I did w/o any real struggle. I think the La402 could easily lift 1300-1500lbs when they report only 1000 lb capacity, much closer to what they list as breakout force.
What all this means, is unless you need to dump a load at full height, like over the side of a pickup or dump truck, you could probably run a 300-500 lb 4n1 and still have 1000lbs of lift capacity.
The 402kg lift capacity of your loader is the weight it can lift to full height at mid bucket. All loaders can clearly lift substantially more than their rated capacity a few feet off the ground which is why you could lift the BH.
