NH TC29D - PTO Disengaging
   / NH TC29D - PTO Disengaging #1
cnvread
Pensacola, Florida
New Holland TC29D
After 4 years and 450 hours, my PTO started disengaging while mowing this morning. It will still engage without issue and mow for approximately a minute. As I move into an area where the torque demand on the 5' rotary cutter increases, the PTO engage lever backs out about 1.5" and the cutter stops. There is not really any sound when it happens, and if I watch the lever it backs out fairly smoothly.
I thought the engagement might not be sufficient so I adjusted the linkage to engage the PTO slightly further, but the problem continued without change.
   / NH TC29D - PTO Disengaging #2
Have you checked for any detent mechanism that holds the PTO lever in it's position ?
JC,
   / NH TC29D - PTO Disengaging #3
You will probably find that teeth on the 2 engaging gears are starting to chip away. You can still engage it ok, but when you load it, the wear allows the gears to disengage. You can look at these gears by removing the three-point topcover and looking inside at the gears.
__________________________________________________
Go to partspring.com for all of you New Holland parts needs at reasonable prices
   / NH TC29D - PTO Disengaging #4
I have a TC33D and the same thing happen to me within the first year of owning the tractor. It was so bad that I would have to hold the PTO shift down to keep it engaged. I brought it to the dealer and it was still under warranty at the time. They replace the gears and all the hydro oil because of the metal shavings, the oil is not covered by the warranty.
It is a problem that needs to be repaired as soon as possible. The metal is wearing away and is getting into your Hydro fluids and it can cause problems in other areas.
Hope that helps
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A51694)
2018 Regal 29OBX...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
