Looks like I am going to have a prob with the service manual
   / Looks like I am going to have a prob with the service manual #1
hrlyeagle
Sierra Vista AZ
Century 2035
So can anyone help me solve my main problem. The glow plugs don't work.
When I disconected the wire on the engine side of the firewall, and ran a hot wire to them they heated. Is there a timer for them, a relay or what, and where?
If I can't get any info, I guess I will just install a manual switch to turn them on.
   / Looks like I am going to have a prob with the service manual #2
I was told by my Century dealer's mechanic that service manuals were not available to the customer. Service manuals they use are from the Century company and are company provided. I did a google search and found several operator's manual available for the Century 2035 but I am not sure if that will help. I also found a web site called...Yesterday's Tractor co. at 1-800-853-2651..they offer service manuals for several brands of tractors. Might want to give them a try.:D
   / Looks like I am going to have a prob with the service manual #3
Which tractor ?
I have a shop manual, I'll look it up if it covers your tractor model.
There is a glow plug timer on the 2035.
On the rear side of the firewall look for a tall thin object on the right, that is the turn signal and 4 way flasher, the glow plug timer is just to the left of that. On the front of the firewall there is a glow plug relay R3 in the top right corner
First check fuse #4, counting from the top on the 2035, count from right on 2045, that is 5 amp and protects the glow plug and manifold heater control.
Let me know if this helps - or not.
I could fax you some troubleshooting pages if needed, but please do check those fuses first.
   / Looks like I am going to have a prob with the service manual #5
Do you need glow plugs in AZ? I haven't used mine since I got the tractor.
   / Looks like I am going to have a prob with the service manual #7
Reg try again. Fixed link - actually updated it with the correct 2035/2045 electrical diagam. The first post was attempting to link to the 3035/2045 diagram, which is slightly different that the 2035/2045 - mainly around the glow plug wiring.
Which tractor ?
Thanks for the info, I will look into it this weekend.
I don't live in Phoenix, it gets down to the 20's here, and much colder in other parts of AZ.
   / Looks like I am going to have a prob with the service manual #10
If all else fails you can get me a ticket to fly out there (from Boston, First Class) with my shop manual and help you fix it.
Yeah, I've driven rental cars on snow and ice up there (-:
BTW, the shop manual is a little confused in translation.
Front/rear of the firewall isn't consistent, and left/right isn't always "as viewed from the driver's position facing to the front of the tractor".
"The Tractor's Mass" in the electrical sense means chassis ground - I guess 'chassis ground' is an odd term, but supposedly English is the hardest (& oddest) language to learn.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
