kubota backhoe/tractor question
   / kubota backhoe/tractor question #1
7acres
Member
Upstate NY
Kubota B1750
I have a b1750 (20hp) with a FEL and located a kubota 4530 3pt backhoe.
Can the B1750 handle this backhoe?
Thanks
   / kubota backhoe/tractor question #3
Thanks
It has its own pump powered by the pto so it should work OK. But I couldnt say how well it would 'sit' on the tractor.
Theres a parts diagram for it (and your tractor) here..
Kubotabooks.com
   / kubota backhoe/tractor question #4
Thanks
With a closed system shaft driven pump yes 20HP will handle any demand except multiple functions will slow with an open center hydraulic system. Mr. Brown brings up an important safety issue using a three point hitch, don't do it, get a fabricated frame to attach the hoe to. If any link would fail under breakout pressure on the bucket and stick you could be severly injured. The choice is yours and also the risk. People argue the outrigger will take this force but I'm telling you if a lower link breaks, they simply becomes a cantilever forcing your body into a fulcrum against the control valves, the rops ( if equipped ) or an unforeseeable pinch point due to the vector of the unleased force. Please think about this before you mount a backhoe to a three point hitch and place your body on top of it.
   / kubota backhoe/tractor question #5
3pt hitch backhoes are also a lot harder on the tractor than a subframe model. I recently purchased a subframe hoe, and then came across a 3pt hitch model a little bigger for a lot less money. I plan on refurbishing the 3pt and using it, but my JD is a lot more tractor than the little hoe's are used to, so the tractor should handle it ok. If not, I will be wishing I had kept the subframe model instead of selling it (sometime soon?)
David from jax
Kubota L4630 (A50123)
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
UNUSED WOLVERINE SP-15-84W 84" SNOW PUSHER (A51248)
UNUSED WOLVERINE...
KMC 5610 LOT NUMBER 32 (A53084)
KMC 5610 LOT...
