Info on 8" clamp trac vac
   / Info on 8" clamp trac vac #1
redharley
Gold Member
central, Pa
BX2230
I have and older trac-vac looking for a source for a 8" clamp with like a buckle or cam lock so I don't have to use a screwdriver when changing from mower deck vacumm to my hand vac attachment.Thanks for any info
   / Info on 8" clamp trac vac #2
McMaster Carr Item 5215K14:
The quick-release latch makes these reusable clamps good for temporary hose and tube connections and any applications that require repeated use. Band and housing are Type 304 stainless steel for good corrosion resistance. Band is 5/8" wide and 0.031" thick. Screw is Type 410 stainless steel and tightens with a slotted screwdriver or 8 mm hex nutdriver. Temperature range is -4ー to +428ー F.
300-lb. clamps have a latch that is 0.87" (22 mm) wide. 850-lb. clamps have a latch that is 0.96" (24.5 mm) wide.
Looks like you still need a screwdriver tho.:(
larry
   / Info on 8" clamp trac vac #3
larry
You only need a screwdriver for the initial installation. I use this clamp for the 8" hose on my vacuum system. One the clamped tension is set, you can pop the clamp on and off as needed with the quick release. It's just the thing when you need to clear clogs.
   / Info on 8" clamp trac vac #4
Good news! Couldnt tell from the picture that the clamp would pullit up tight.
larry
   / Info on 8" clamp trac vac #5
Great Post I have been driving around with the nut driver for the hose clamps on my 6inch trac vac. Looks like exactly what is needed for that. But at a cost of 36 and 38 each plus shipping that is pain full for a single snap lock hose clamp. I see those are stainless steel which would mean it would probably be the only ones I ever buy for that machine. I would need 2 one for the impeller side and one for the mower boot side. Seems a bit pricey compared to a 1/4 inch nut driver I toss in the cup holder when I am mowing.
5 1/8"-6 7/8"130-1751305215K13 $36.45
6 3/4"-8 1/2"170-2151305215K14 $38.36
   / Info on 8" clamp trac vac #6
I only use one of these clamps at the mower deck boot end, because that end need a tight clamp to keep the hose from pulling off. I use a regular clamp at the impeller end, tight enough to hold it on but loose enough that I can slip it off without needing to loosen it. Obviously your situation may be different.
Thanks for the info Guy's.This looks for what I am looking for.I am always unhooking from the mower boot to hook up to a 15' hose to vac beds and such,this would make it less of a pain for sure.I will think about if the pain in the wallet is worth it,i was hoping for $14.95.
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
Genie GTH1056 (A50120)
2016 Genie S-45 4x4 45FT Telescoping Boom Lift (A50322)
2016 Genie S-45...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
