Satoh Buck 3 pt down pressure.
   / Satoh Buck 3 pt down pressure. #1
mtjohnso
I have recently acquired my fathers Satoh Buck that he had and beat up pretty badly. I cleaned the diesel filter and got the tractor running. Then I cleaned the hydraulic filter and got the hydraulics working. When I tried the 3 pt it would go up but not down. I only recently (15 minutes ago) found out that the hydraulic cylinder for the 3 pt is single acting and uses the weight of the implement to cause the 3 pt to lower when the lever is in the down position. So the question that i have is how much weight is required to make the 3 pt go down? I stood on the arms and that was not enough (190 pds).
I find that when I let the tractor sit for several days that the three point has lowered back down which would lead me to blieve that the O rings need replacing in the spool valve.
Also i find that the front bucket is now slow to lift. I checked the fluid level and it is fine. I cleaned the hyd filter only abotu 2 months ago. Of course when the fluid was exchanged fromt he cyclinders, maybe that brough gunk into the transmission. Thoughts. Is there someplace that a pressure gauge can be added to check the pump and valves and such?
   / Satoh Buck 3 pt down pressure. #2
Check for a knob or small lever under the seat that adjusts the down speed of the 3 point lift. On my Mitsubishi, turning this knob all the way clockwise prevents the lift from lowering.
   / Satoh Buck 3 pt down pressure. #3
So, does anyone know if the Buck has this "knob".. I have a snow plow on the front of my Buck, that runs off the same place as my 3pt hitch. Problem is when I lower my plow, my 3pt lowers as well, and I have a carry all back there which drags a bit. Not a huge deal, but would rather is stayed up while plowing snow.
   / Satoh Buck 3 pt down pressure. #4
Yes, the Buck has this knob. I adjust it all the time when changing implements from the light grader blade to the heavy mower. If you are sitting on the seat it's under your crotch.
   / Satoh Buck 3 pt down pressure. #5
ahhhh fantastic.! This will help me with my snow plow!
Thanks Evan.!
   / Satoh Buck 3 pt down pressure. #6
Thanks Evan.. found it.. not a "knob" on my machine, more like a set screw, but I turned it pretty much "OFF" so only my snow plow is affected by the up/down lever. Works awesome.
Now, if I can figure out who you guys get hydraulic impliments on the front of your machines. Like : Loaders, 4-way plows, Hyd snowblowers, etc etc..
And also front weights.. I have yet to do that too.. Spring time I suspect.
Thanks again
   / Satoh Buck 3 pt down pressure. #7
I find that when I let the tractor sit for several days that the three point has lowered back down which would lead me to blieve that the O rings need replacing in the spool valve. ...
I would suspect first that oil is leaking past the 3-pt lift piston. It is not uncommon for those to bleed down over time like a lot of hydraulic equipment such as floor/bottle jacks, etc.
   / Satoh Buck 3 pt down pressure. #8
Dsavave there is a triangular plate on the left side under the seat. Valley power can make you a replacement plate that has hydraulic ports. I got one for my Buck and it worked perfectly. I had the local shop make up the hoses I needed to connect to my Koyker 110 FEL. This worked out great and I no longer need cent end weights. Good luck! Rowdy Raven
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
KUBOTA ZD1211 (A53084)
