The Low Down on Dirt..
   / The Low Down on Dirt.. #1
txkevin
Austin, Texas
Kubota BX 24
I need to order some top soil or sandy loam. The question is, how much.
I know soil is sold by the yard. How many yards are in a standard dual axle dump truck anyway? Is this square yards? Basically I need to figure out the Yard volume to figure how much this covers a given square feet a given number of inches with top soil.
Anyone got any insight into this?
   / The Low Down on Dirt.. #2
The load is measured in cubic yard. It would be hard to say how many yards would be on a load because a load is figured by weight. For ex, a yard of cotton would weight less than a yard sand, but each would still be a cubic yard.
   / The Low Down on Dirt.. #4
1 cu. yd. = 27 cu. ft.
Length(ft) X Width(ft)X Thickness(in) = Vol (cu.in.) = Vol (cu. yds)
3 X 3 X 36 = 46656 cu.in. = 1.0 cu.yd.
To apply 1 in. of soil to a yard that's 100 x 100 ft you need 31 cu.yds
Length (ft) X Width (ft) X Thickness (in) = Vol (cu. in.) = Vol (cu. yds)
100 X 100 X 1 = 1440000 cu.in.= 30.9 cu. yds
To apply 3 in. of soil to a yard that's 100 x 100 ft you need 92 cu.yds
100 X 100 X 3 = 4320000 ci.in = 92.6 cu.yds
   / The Low Down on Dirt.. #5
It depends on who loads the truck! A ten wheeler is generally 12-15yds, and a triaxle is 15-18, or maybe even 20. Lots of variables - how wet is it when loaded, do they care about being legal with regards to weight, do they heap it up or do they have a small machine loading that can't really reach well enough to do that? Know what I mean?
   / The Low Down on Dirt.. #6
I have to admit I got a little confused by lp333's numbers. It looks right but for me it is easier to keep all the units (feet & inches) the same so I do it this way.
To cover an area 100ft by 100ft 3inches deep, my math would look like this;
100ft x 100ft x .25ft = 2500 cubic feet / 27 cubic ft per yard = 93 cubic yards or about 5 tri-axle loads worth.
Which is a lot of dirt no matter how you add it up.
Matt.
   / The Low Down on Dirt.. #7
I go by tons not yards.
A couple of years ago i got 30 tons of real nice top soil .
Then again last Feb i got about 30 to 36 tons of fill dirt .
got all this free including delivery .
Otherwise this would have cost me about 1200 to 1400 dollars.
   / The Low Down on Dirt.. #8
33 tons of fill dirt is only 26 cubic yards. Our price of fill has doubled since Katrina and it is still only $120 for 18 yards delivered. You must have some real expensive top soil. :eek:
   / The Low Down on Dirt.. #9
txkevin requires topsoil not fill, most places that deliver topsoil around here screen it out for rocks so it's easier to landscape with. Topsoil is precious compared to fill.
   / The Low Down on Dirt.. #10
here in Tx "sandy loam" is mostly sand with a little clay mixed in ...not black topsoil like up north. How good the sand/clay mix is depends on where it comes from....I've seen it really pretty and really poor .... just depends. I always went with 80 sq ft / 4" deep = 1 yd of material and 1 yd = just over 1 ton. Depending on if you have room for excess or not -- order more (better) than you need (figure 1.5 ton per yd) or if you end up a bit short - figure out a secondary way to get the rest.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
