Need a quick answer-->Weight LA1153
   / Need a quick answer-->Weight LA1153 #1
chuckcou
Kubota doesn't list the weight of the loader on the website. I am trying to figure out what size trailer to get for a M7040 Trailer with the LA1153 loader.
I have a Dually that has a goose neck, but I might just go with a bumper hitch.
Thus--
>>>>>Weight of LA1153?
>>>>>Trailer size you would recommend?
>>>>>Trailer gvwr you would recommend?
Thanks
chuck
   / Need a quick answer-->Weight LA1153 #2
Kubota doesn't list the weight of the loader on the website. I am trying to figure out what size trailer to get for a M7040 Trailer with the LA1153 loader.........
The simlar model LA1150 loader is 1500 lb plus bucket (400-500 lb) so it adds about a ton. Are the rear tires going to be filled? That will add 800-1400 lbs depending on tire size and fill material. With a rear implement, a 10k gvwr trailer will be on the small side. As always, prompt cheerful refund if info is bogus - Dick B
Lift Gate (A52377)
Lift Gate (A52377)
HARDEE RD60M LOT IDENTIFIER 144 (A53084)
HARDEE RD60M LOT...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2018 COLOMBO TM LOT IDENTIFIER 171 (A53084)
2018 COLOMBO TM...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
FRONTIER LP2196 LOT IDENTIFIER 101 (A53084)
FRONTIER LP2196...
