Mowing a soccer field
   / Mowing a soccer field #1
ironpen
Gold Member
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
I need to mow a soccer field and get the smoothest cut possible. Is a flail the answer? Total cut area maybe 2 to 2 1/2 acres. Size and brand? I have either a 33 or 75 HP tractor I can use. Thanks
   / Mowing a soccer field #2
had a friend use my finish mower to do a football field for a peewee league work just fine shuold do for what you want
I am currently doing that and it just isn't smooth enough. This is for a serious league. Not making fun of PeeWee games, but I need to go a step beyond. Thanks
   / Mowing a soccer field #4
In the tractor world, a finish mower is as good as it gets. You may do a bit better with a commercial mower (zero turn type) - but I doubt it. Also check that your finish mower is configured properly and that the blades are sharp.
Mike
   / Mowing a soccer field #5
How 'bout a reel type mower? I always thought they had the nicest cut, if they are sharp and properly adjusted.
   / Mowing a soccer field #6
And there are no weeds.
Andy
   / Mowing a soccer field #8
yes sir!
Go to a golf course and check their mowers.
great suggestion, "ironpen" will find out that 'Reel Mowers' are used for the greens (very very smooth). some golf clubs will use them on the Fairways too.
i will assume that a good weed control program has been initiated for the game field's grass type.
   / Mowing a soccer field #9
Try this!
Use lightweight fairway mowers from JohnDeere for your golf course maintenance needs
A well maintained, high quality flail mower will give an excellent finish, but the BEST finish will be a "golf course" turf mower of some description. (bed knife mower?) Check out the mowers used to mow major league ball park turf, ect.....
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
