1958 Ford 841 temp rises pulling bush hog
   / 1958 Ford 841 temp rises pulling bush hog
Thanks for the info, is the thermostat in the top hose?
   / 1958 Ford 841 temp rises pulling bush hog #12
Yes. Remove the upper hose at the cylinder head water outlet elbow. Remove the bolts that hold the elbow and remove it to get to the tstat. Gas tractor full open at 180F, diesel open at 202F. They both start to open 20 degrees sooner.
Be sure the fan belt is tight. 1/4" deflection at the center of the belt. THe pump should put out 18 to 19 gpm. That's a lot.
2020 ISUZU NPR 18FT BOX TRUCK (A52141)
2020 ISUZU NPR...
Bobcat 60" Skidloader Sweeper (A50774)
Bobcat 60"...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
EZ-GO Cart (A50121)
EZ-GO Cart (A50121)
CAT 973 (A47384)
CAT 973 (A47384)
