Totally confused--12K trailer Class A license
   / Totally confused--12K trailer Class A license #21
And I'm pretty sure it's the opposite;
It's about weights and not about capacities. No way it's illegal to tow a 3000 lb trailer empty that is rated to 12K with a pick up truck. I talked to my CHP buddy and he said that's why they carry scales in their rigs; the type that each tire rolls up on. So they can weigh the load on each tire, add it up and come to a total.
I used the one ton as an example of how you can stay under.
The same 12K trailer EMPTY on a 16,500 GVW Kodiak or similar WOULD require a class A license - FEDERAL REQUIREMENT {CHP roolz notwithstanding, etc}.
Weigh stations and spot check Porta-scales are to check for actual overweight infractions, which can be a whole _NOTHER set of tickets if you "qualify" (-:
License CLASSES are based on load CAPACITY !!!, primarily of the combination (Total rig).
26,000 is the magic number for class A - although I think I've seen 26,001 somewhere in the CMRs
Reg What you say makes total sense to me. For me, I am looking at purchasing a 12K trailer to load it with a B7800(or about 3000lbs).
Thus, my trailer will have a total weight of about 6000K. I will be pulling it with a Chevy 3500 Duramax Dully. I know for a fact that my total weight will be no where close to 26K.
So, if what you say is true then I don't see any reason to derate the trailer. I then also don't see any reason to get a non commercial class A license.
Does anyone see it any different???????
   / Totally confused--12K trailer Class A license #23
If you have a truck with a gross max of 11,200 (and you do) and the trailer is 12k that is under CDL for most states. BUT!!!! the land of fruits and nuts, AKA Cacklefornia, does require you to have a CDL to tow over 10k. It's in the regs posted.
From the Cacklefruitorinan DMV
A noncommercial driver license is issued in the following two classes:
  • Noncommercial Class A
  • Noncommercial Class B
A Noncommercial Class A license is required if you tow:
  • a travel trailer weighing over 10,000 lbs. Gross Vehicle Weight Rating (GVWR) which is not used for hire.
  • a fifth-wheel travel trailer weighting over 15,000 lbs. GVWR which is not used for hire.
  • a livestock trailer that is not for hire, weight over 10,000 lbs. GVWR but not over 15,000 lbs. GVWR, and is operated within 150 miles of the farm by a farmer to transport livestock.A noncommercial driver license is issued in the following two classes:
If you want the extra capacity, why not get a 14k gooseneck?
jb
   / Totally confused--12K trailer Class A license #24
I have read post like these in the past; and some have been given differing info from 2 or 3 different people in the same state, same dept, and then different info a week or so later. Even when it is written where it can be interpreted by the average individual one can still get differing answers. One hot topic that makes some mad is the motorhome stuff, no offense to older folks since I am approaching old age myself, but a half blind, half deaf person can drive just about any size motorhome anywhere, anytime, and tow a large trailer behind it with no attention from law enforcement. Lots of people have the derated Kennworths, Freightliners converted to single rear axle towing 36' fithwheels with just a regular drivers liscense while someone with a small skid steer behind a 8,800-9,400 GVWR pickup is on the side of the road getting a grand worth of traffic citations. The real answer is there is no real answer; as some info is written to be open to different opinions as to who is reading it.
WOW!!!! This topic is all over the place with answers!!!! No two answers are the same. California DMV really needs to clarify thing a bit.
1st--Non-Commercial Class A license--- Most agree that if you are over 10K or 26K Total(Tow vehicle and trailer)
But here is the real question that need to be answered---
Is it the ACTUAL weight your are towing or
Is it the CAPACITY of the trailer you are towing????
I would think it would the your actual weight you are towing---If this is true then why would anyone want to derate a 12K trailer????
   / Totally confused--12K trailer Class A license #26
It's about weights and not about capacities. No way it's illegal to tow a 3000 lb trailer empty that is rated to 12K with a pick up truck. I talked to my CHP buddy and he said that's why they carry scales in their rigs; the type that each tire rolls up on. So they can weigh the load on each tire, add it up and come to a total.[/QUO
Tell your CHP buddy he is full of it,, I have a Dodge, SRW one ton and pull a Bri-Mar 18 ft 12,000gvw trailer that weights in at 3300 lbs, all the time across the Union CT scale,, There is no way CHP can stop a one ton pick up pulling an empty 12,000gvw trailer as you just claimed.. I've had a class A since 67, which is now called a CDL A. Combined weight is the key,, all cannot exceed 26,000 and if it does, a CDL is needed. I have also ran into new cops at the Union scales who read "any trailer over 10,000lbs" but they do not continue to read on to the combined weight of 26,000, In other words, as written, it is open to many interpretations, and GOd knows as many troopers and local cops are out there, is equal to the interpretation numbers out there also.
   / Totally confused--12K trailer Class A license #27
THis subject has beat to death in many a forum. Here in Minnesota you will get the same run around. The actual rule reads trailer over 10001 LBS needs CDL.
I solved it by purchasing a trailer stickered for 9990 with 12,000 axels. I only haul about 5000 so no big deal. It would have been nice to have a larger trialer sitting there. The DOT aorund here will go after you for CDL if you are engaged in commercial work by there judgment. Also they will dip anyones tank.
DANOCHEESE
Yes-- You are correct in the subject is being beat to death, but all the answers are different.
My issue is why do you want to derate a trailer if you don't need too?
In my case I am going to buy a 12K trailer. Yes, I can derate it, but if CDL is based on weight then there is no need, too. Thus, when I sell the trailer I would think it would be worth more money due to the fact that either commercial or non-commercial could use the trailer.
I do understand each state is different. In my case I am trying to figrue out California DMV regarding a 12K trailer.
So far I have not been sucessful with DMV, friends, or this thread. I believe the answer is based on the actual weight of the trailer. But in the back of my mind I keep trying to figure out why anyone would derate a trailer if they don't need to.
   / Totally confused--12K trailer Class A license #29
OK, I'll take ONE MORE TRY at adding clarity - not the kind that politicians do the day after they have been caught in "conflicts of differing truths" (-:
My posting was based on FEDERAL regulations, which set MINIMUM standards for commercial vehicles. States may and DO add to those.
The Massachusetts CDL manual states;
You must have a CDL to operate;
A single vehicle with a Gross Vehicle Weight Rating (GVWR) of more than 26,000 pounds.
A trailer with a GVWR of more than 10,000 pounds if the gross combination weight rating is more than 26,000 pounds.
A vehicle designed to transport more than 15 persons (including the driver).
Any size vehicle which requires hazardous materials placards.
(Your State may have additional definitions of CMVs)
Note: I take that last parenthetical statement as an indicator that this is a re-print of the Federal CMV licensing manual with a Massachusetts cover sheet on it.
My point is "Gross Vehicle Weight RATING " is the determinant for license classes, not actual weight across the scales.
Also the trailer over 10,000 is a conditional "IF" with the 26,000 pound combination GVWR.
How much MORE restrictive California is would be best answered by THEIR DMV, but the minimum Fed requirement is as above.
I suggest a visit to the CAL DMV and request a copy of their CDL manual, which will probably be the federal requirements with whatever State addendum they have added.
.....and just before submitting this post I opened another tab to look 'em up.
http://www.dmv.ca.gov/pubs/cdl_htm/sec1_a.htm#who
I think this says it all;
Who Needs A CDL?
To operate commercial vehicles, you must apply for a CDL. Only California residents may obtain a California CDL. Residency is established by any of the following: registering to vote here, paying resident tuition at a public institution of higher education, filing for a California homeownerç—´ property tax exemption, obtaining a license (such as a fishing license), or any other privilege or benefit not ordinarily extended to nonresidents. You need a CDL if you operate a vehicle or combination of vehicles which requires a Class A or Class B license or Class C license with endorsements.
A commercial motor vehicle is a motor vehicle or combination of vehicles designed or used for either the transportation of persons for compensation or property and:
* Has a gross vehicle weight rating (GVWR) of 26,001 pounds or more.
* Tows any vehicle with a GVWR of 10,001 pounds or more.
* Tows more than one vehicle or a trailer bus.
* Has three or more axles (excludes three axle vehicles weighing 6,000 pounds or less gross).
* Is any vehicle (bus, farm labor vehicle, general public paratransit vehicle, etc.) designed, used, or maintained to carry more than 10 passengers including the driver, for hire or profit, or is used by any nonprofit organization or group.
* Transports hazardous materials requiring placarding.*
* Transports hazardous wastes (Health and Safety Code ï½§ï½§25115 and 25117).*
Again, it is about Gross Vehicle Weight Rating, i.e. CAPACITY, not actual weight across the scales.
Now the "designed or used for either the transportation of persons for compensation or property and:"
COULD be confusing.
Various combinations of the "ORs" could except or include you.
e.g. You may or may not be USING it for compensation, but if it was DESIGNED for transportation for compensation - they can classify it as a commercial vehicle.
I really don't know how well a claim that a 12K trailer is "designed" for recreation use would hold up.
YEAH if it were a BOAT trailer,
DOUBTFUL if it is an equipment trailer.
Sorry, I guess this post muddied the waters even more.
Just like a politician's "Clarification" (-:
   / Totally confused--12K trailer Class A license #30
This probably isn't going to help anything (I think we passed that stop a while ago) but what exactly do you do, to have a trailer "derated"? Just paint a lower GWR poundage on the side of it? Does the DMV have to bless the derating? Does the manufacturer have to derate it? I'm just curious.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2014 Honda Accord (A50324)
2014 Honda Accord...
2005 Nissan Pathfinder (A50324)
2005 Nissan...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
UNUSED FUTURE MINI SKID STEER STRAIGHT DIGGING ARM (A51244)
UNUSED FUTURE MINI...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
