7108 loader problems
   / 7108 loader problems #1
pal21
I have run into two problems which seems to have occured simultaneously.
I lost the float completely and the joystick will not pop back to neutral by itself when lowering the boom. I can only stop it by pulling the stick back manually. All other functions are normal.
I did a search and other posts indicate this may be caused by bent linkage. I removed the joy stick cover and the linkage seems a little too stout to be easily bent.
Do the other posts I read refer to internal linkage or am I misreading?
Thanks for any replys.
   / 7108 loader problems #2
You have problems in the detent assembly which is attached to the opposite end of the valve spool from the joystick linkage.
Anyone know where I can find a parts breakdown on the control valve?
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
