Modern hydraulic fluid in antique pump?
   / Modern hydraulic fluid in antique pump? #1
lhfarm
Central Indiana
NH TC40DA
We have found a crankshaft driven hydraulic pump for our farm jeep 3pt hitch project. This is a new-old-stock (NOS) probably made in the early 50s. The instructions for the lift say to "fill tank with 5 quarts S.A.E. 10 motor oil." We have been operating the lift with a newer electric pump and have used generic farm store hydraulic fluid in it. The question is, other than being "authentic", is there any reason we shouldn't use modern fluid instead of motor oil?
Thanks,
   / Modern hydraulic fluid in antique pump? #2
In the 50"s they used non detergent motor oil and I don't know anyone with old cars that uses it anymore if it's even available. Lubrication products have improved greatly over the years and I can't think of any reason not to use the modern products.
   / Modern hydraulic fluid in antique pump? #3
Use a good hyd oil.. or a UTF oil.. should be fine.
I have antique tractors from the 40's up that am now using modern UTF oils in place of other oils that have been obsoleted over the years.. etc.
soundguy
   / Modern hydraulic fluid in antique pump? #4
We got some ND at auto zne for our pressure wassher.
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
2011 Toyota Corolla (A55758)
2011 Toyota...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
