Reverse wheelies, is this normal?
   / Reverse wheelies, is this normal? #1
MyKubota
Northern New Jersey
Hello everyone and thanks for all your knowledge here on this site. It was quite helpful in choosing my first tractor. Anyway is it normal for my machine to stop so quick when I let of the reverse pedal? It seems to gradually stop while going forward. I cant imagine reverse wheelies are a good thing to do! Is the pedal spring tension adjustable? Thanks.
   / Reverse wheelies, is this normal? #2
There is threads and post on TBN ; do a search an C what U come A Cross.
All the forums I'm involved with and I forgot to do a search. :( Found out it seems to be a common symptom for now.
   / Reverse wheelies, is this normal? #5
This has become a known issue with the BX xx50 series.BX24. Kubota addressed it with the BXxx60 series/BX25. I was told by my regional Kubota service rep that the issue is in the dynamic braking inside the transmission, so, no, there's no adjustment or easy fix for it.
   / Reverse wheelies, is this normal? #6
One of the things that I have watched many people do is to remove their foot far faster from the reverse side then the forward side of the petal while operating the tractors. I normally use the top of my foot on the bottom of the forward petal to go in reverse. I've found that it is easier to not have the reverse issue for most operators.
   / Reverse wheelies, is this normal? #7
Try laying a 12" piece of 2X4 parallel to the pedals to rest your heel/toe on while operating them, it gives you better control of the rear pedal and you don't tend to push the pedal so far down. It definitely helps, but is not a cure. Making a block that would go under the rear pedal that would limit its travel (and your reverse speed), might help reduce the severity of "jerk", I have not tried that though.
   / Reverse wheelies, is this normal? #8
I hate to say it but yeah its normal. "normally" i should say no way since anything that costs over 15G shouldnt be a neck snapper! i have found that tightening and cranking up the HST helps me to make it easier to feather it but its no way of solving the problem. i noticed with the weather colder now the neck snapping is more prevalant now then before and i may readjust it back too where it was. when the weather was warmer this summer its seems to help some ( better then nothing) but i dont want to keep adjusting the HST travel and spring adjustment biyearly! :mad: sigh i wish there was a better way! i started a thread on this but its not a cure when i tried it. There hasa GOT to be a way other then trading in for a BX25. I love my BX24 and why should I get the BX25 without 3pt hitch for 1K more and have to pay extra for it ?!
   / Reverse wheelies, is this normal? #9
Mine does it to. If you are really carefull, it won't jerk, but mine does at least half the time. If you are in low range, it doesn't do it either.
   / Reverse wheelies, is this normal? #10
Look on the bright side, You don't notice it when you are in the snow!!:cool:
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
