Moldboard Plow Sizes
   / Moldboard Plow Sizes #1
jdfire
Michigan
Ford 1620, hydrostatic FWD
Hi Everyone. When referring to the size of a moldboard plow, such as 12, 14, or 16", which part of the moldboard is being measured? Thanks.
   / Moldboard Plow Sizes #2
Width of cut. (You aren't actually measuring any individual part of the bottom) Measure from one edge of a beam (frame) to the same point on the beam next to it .
   / Moldboard Plow Sizes #3
jdfire,
The part of the moldboard plow that you are referring to is called the "plow share". It's the bottom part of the plow that has the rounded point on it. The "moldboard" is the large curved piece of metal that is attached/connected to and above the plow share. The plow share's rounded point lays on top of the "landslide". It lays on the ground and also sticks out behind the plow. Standing behind the plow, measure the distance from the landslide to the outside lower edge of the plow share.
This measurement will tell you what size moldboard plow you have. This is the width of a furrow the plow will make. Also, take half of the measured width of the plow, and that's the proper depth the plow should be used at. A 12" plow will make a 12" wide furrow at 6" deep. I would have taken a pic of my 10" plow, but my wife took the digital camera with her while trick or treating with the kids tonight. If you don't understand, I can take a pic later, and then post it. I hope this info will help answer your question.
Thanks for the replies and the lesson in plow anatomy! This forum is awesome. :)
   / Moldboard Plow Sizes #5
Hi! Thanks for the post it's very useful. Can you please send me the picture (of the MBP Bottom) through email so that i can better understand the concept of the size of the bottom.
Thank you!
Kubota M5-111 (A53317)
2017 John Deere 5090GN (A53317)
2017 John Deere...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
John Deere 5105M (A53317)
John Deere 5105M...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
