Stress crack in wheel motor
   / Stress crack in wheel motor #1
smilindave
Dayton, Pa
Power Trac 425
Front wheel motor on my 425 started leaking a while back. The other day it finally blew. Oil everywhere. I took the motor off and had new seals put in. Still leaked. After closer inspection, i found a hairline crack on the face of the motor near the main seal. Is there any chance I can have it welded, re-machined and a new seal kit installed?
   / Stress crack in wheel motor #2
What kind of wheel motors do you have? If your machine is mid 2003 or newer, then they are Whites. You can get a new motor for a little over $300, if you shop carefully.
Welding up a stress crack to withstand 2500 PSI seems like a tricky proposition. Maybe a good weldor could do it, if the area in question did not have a precision machined finish. You also may be able to buy a new case for the motor.
Can you provide a photo of the leaking area?
The motor is a White form a 2000 model. I'm worried about getting a good tight weld that will seal the crack, especially in the area around the seal. as for the picture, I don't have access to a digital camera.
   / Stress crack in wheel motor #4
Just curious if you were using reversed wheels?
I did have the back wheels reversed for a while to move some dirt, but when I was done I switched them back. However it is one of the front motors that went bad.
   / Stress crack in wheel motor #6
Without knowing where the crack is, it is hard to comment in detail. In general, welding a hairline crack is not recommended on a machined part, as you need to penetrate deep enough into the metal to fuse the body.
If it just on the lip that holds the o-ring, maybe. However, I think that the welding/machining bill would outweigh the price of a new motor.
All the best,
Peter
thanks, i will probably just end up getting a new one just to be on the safe side.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2024 KMC 7406 (A53084)
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
SAMSUNG SMART REFRIGERATOR (A54757)
SAMSUNG SMART...
