Quick Coupling size BX2350
   / Quick Coupling size BX2350 #1
Zick
WI
BX 2350
Tried searching but didn't find anything.
Anyone know the quick disconnect coupler size on a BX2350? Are they 1/4, 3/8, 1/2?
This looks like the right type but I'm not sure on the size.
MSC Item Detail
MSC Item Detail
   / Quick Coupling size BX2350 #2
MSC Item Detail
MSC Item Detail
I have just been looking into this as I needed to replace some of the Buna-N o-rings that I damaged on some female connectors. Kubota doesn't service this O-ring as a part and will only sell the full disconnect. Sell price was $30 for a $12 fitting. Knowing that I only needed a $.50 or less o-ring. Here's what I found.
Kubota uses for the FEL/Plow-Other a ISO 7241-1 series B Quick connector. the size is 1/4". The series that you pictured from Parker is correct. These are an industry standard ISO fitting and are interchangeable between manufacturers. Here are a few:
Parker H2-62
Snaptite 72c4-4f
Safeway S105-2
Awesome, thanks for the info!
2009 Dodge Ram 5500 Utility Truck (Diesel), VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
2018 International DuraStar 4300 Dump Truck, VIN # 1HTMMMMNXJH633369 (A51572)
2018 International...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
