TC40DA no power in acc plug (behind seat)
   / TC40DA no power in acc plug (behind seat) #1
chuck1975
NW Indiana, basically now a suburb of Chicago
new holland 1920, ferguson to35, case 1948 dc, kubota (my brothers but left here as he has no where to keep it)
Anyone know how to check fuses and line for this?
Anyone use this power slot? What has been your best uses?
Chuck
   / TC40DA no power in acc plug (behind seat) #2
fuse block is behing dash panel.
   / TC40DA no power in acc plug (behind seat) #3
I know this may be obvious, but did you turn the key switch ON? Fuse #3 is the fuse that supplies power, but the key switch must be ON to power the plug. The OEM light has an ON/OFF switch located on the light so you can turn it OFF if you don't want the light.
   / TC40DA no power in acc plug (behind seat) #4
I never used mine.
I could if needed use it for my cell phone.
Thanks Guys I was hoping that the fuses were not behind the display.
Chuck
   / TC40DA no power in acc plug (behind seat) #6
Chuck
It's easy to get to the fuses. Just remove the two screws holding the instrument panel in the cowling, lift it up, and the fuses are on the left hand side. They are numbered from left-to-right.
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2001 Ford Ranger Pickup Truck (A51692)
2001 Ford Ranger...
Polaris Side by Side (A50324)
Polaris Side by...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Isuzu NPR Beverage Box Truck (A51692)
2016 Isuzu NPR...
