per requests; pics of my dump trailer
   / per requests; pics of my dump trailer #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Sorry about some of the dark pics
Hmmmm,
Maybe I should'a put this in the "towing rigs and trailers thread"...
   / per requests; pics of my dump trailer #3
Nice trailer.
Chris
   / per requests; pics of my dump trailer #4
Allen, not to sould like a jerk but that trailer looks lightly built. It's all to easy to overload a dump trailer and I think with the construction of you trailer you may have issues. Just my 2 cents best of luck
Matt T.;)
Matt T.;)
Matt, I take no offense to your remark. This trailer is as heavily built as any of the couple of dozen other brand dump trailers I looked at...
PJ, Big Tex, Bir-Mar, Performance etc etc. They all had different means to the same ends, and I'm not sure if I said what I meant to say. :)
As far as over loading, this trailer will be easier than most because it IS 16 foot long and 83 inches wide. The sheer volume of material it can physically hold, depending on what you put in it, is way more than the trailer can safely carry, forget about dumping it. And I guarantee you, I will overload it at some point in time.
Most other manufacturers only make this type trailer, (single tire, tandem axle) up to 14 foot and I needed 16. I didn't want and couldn't afford a tandem dual so I paid my money, got my trailer and I'm happy.
I don't think you're a jerk.
Now let's go outside and play in the dirt. :)
ps,
I've already hauled and dumped two HUGE loads of busted up concrete. It scratched up my bed. :(
   / per requests; pics of my dump trailer #6
I really like that the fenders are built to the side of the dump. My brother's Big Tex has the fenders built to the frame, so they create a void between them and the dump bed. All kinds of crap falls in there and causes the bed to settle back down on the debris. Nice trailer.
   / per requests; pics of my dump trailer #7
Can you be more specific? What exactly are you looking at? I looked at the trailer and it looks ok to me but I'm no expert. I'm looking for a similar trailer and would like to be better educated so I can make a more informed decision.
   / per requests; pics of my dump trailer #8
The steel framing is what's light. The channel is 8" to 10" on my PJ 7x12 dumper. This trailer is so large that there's going to be alot of twist on the frame when the box starts going up. There doesn't look to be enough reinforcement in the frame. That's why these trailers aren't common in the single axle arrangments. Because to buid it large enough and heavy enough needs tandem duals.
Matt T.:D
Just so you know, each frame member is doubled 6 inch channel 3/8th inch thick.. effectively making it about a 5 1/2 x 6 rectangular tubing. It's actually pretty stout and lets the trailer be 2 inches lower than 8 inch material.
I'll admit, it "looks" light but it's not really. JMO
I wish tho' that it had the next heavier scissor lift Mine has the PH516 I wish it had the PH630.
http://www.premium-supply.com/ph630.shtml
Also note the specs on the PJ dump.
6 inch main frame
http://www.pjtrailers.com/detail.cfm?ID=D7
The specs on my trailer
Double 6 inch main frame
http://www.maxeytrailers.com/dumps.htm
Looks like mine has double the steel in the main frame as the PJ.
Not getting defensive here, just stating fact that I discovered when I was shopping for a trailer
   / per requests; pics of my dump trailer #10
My PJ dump is a few years old. I know there making then light now.
Matt T.
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
