Price Check Price on 2120 4WD
   / Price on 2120 4WD #1
pal21
I came across a 1988 model 2120 with 1400 hours for sale. Asking price is $6000. It has the 9x3 transmission, turf tires and no loader. The owner put a clutch and plate in it last year. It looks fairly clean, no leaks or anything major.
I priced out a Woods loader and R-1 tires and rims for it from the local dealer for $5700. All together I would have less than $11,000 in it.
Does this sound like a fair deal? Is there anything I need to take a close look at on that particular model?
I now have a model 1710 with a loader and backhoe with 500 hours that I would sell as I don't need two tractors. Any Idea what price range that would sell for?
Thanks for the help.
   / Price on 2120 4WD #2
I traded a 1710 for a 2120 in 1987 and still have it. The 2120 is a great tractor, larger framed and stronger than all the Boomers except the TC48 and TC55 with which it shares a frame. The only difference betweeen the 2120 your looking at and mine is I have the 12x12 HSS. It all depends on what you are going to do with it. The 9x3 may be a problem for a lot of loader work. The price seems decent.
Andy
   / Price on 2120 4WD #3
The R1's with loader are a good price.
Andy
   / Price on 2120 4WD
Thanks for the reply.
I have seen a few with the HSS sticker on the hood. Can you explain how that differs from a 3x9.
   / Price on 2120 4WD #5
Is HSS = hydraulic shuttle shift?
I have a shuttle shift on mine. I love it. Allows me to go from forward to reverse and back with no use of the clutch. I still need to use the clutch to changes gears.
Bob
   / Price on 2120 4WD #6
Around $14G is what I see from dealers around here. Great tractor; I'll keep mine forever.
   / Price on 2120 4WD
The one I looked at has the shuttle shift on the side of the steering column, left side I think. Is that the HSS you refer to?
   / Price on 2120 4WD #8
Not if it's a 9x3. The shuttle shift tractors have an equal number of fprward and reverse gear/range pairs so that you can just "shuttle" the lever between forward and reverse in the same gear. The lever also operates the clutch and in later 2120's it is modulated so you don't even need to brake.
The 9x3 is a very good tractor. The 12x12 HSS is a great tractor, one of the best Ford ever made.
Andy
   / Price on 2120 4WD
Thanks for the info Andy. Guess I better go back and look at it again. I know for sure that it has the forward/reverse lever on the steering column.
Being as it is a 1988 model, would that mean I would have to clutch it to go from forward into reverse?
   / Price on 2120 4WD #10
No mine is a 1987 and I can go from forward to reverse with out clutching, The difference in later modulated versions is that you don't have to slow down to make it very smooth. When you flip from forward to reverse or vise versa, the system allows the tractor to slow down so that the transistion is velvet smooth. On mine if I don't either pause or throttle down whip lash can occur. Clutching still isn't required.
I still love it after 21 years of hard use.
Andy
2020 JOHN DEERE 6145M LOT NUMBER 79 (A53084)
2020 JOHN DEERE...
2022 ALLIANCE NORTH AMERICA, INC SDG45 GENERATOR (A52472)
2022 ALLIANCE...
TAKEUCHI TL230 SERIES II SKID STEER (A51246)
TAKEUCHI TL230...
TOYOTA 8FGCU30 FORKLIFT (A52472)
TOYOTA 8FGCU30...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
