DEER CLEANING
   / DEER CLEANING #1
flINTLOCK
PA
NH TC40DA 2002
I'll be going to deer camp the week after turkey day and would like to put tractor to full advantage in dressing and skinning the game. Last year, I rigged up a chain and C-clamp to the end of pallet forks to hold deer vertically for skinning. I have hooks on my bucket to attach a chain, but that wouldn't give much separation between deer and bucket to work around. Just wondered what other thoughts might be out there.
   / DEER CLEANING #2
Hang deer in tree with chain.
Grab strap.
Skin deer down past hind legs.
secure strap on bunched up hide.
secure other end of strap to tractor.
drive away.
Deer skun.
   / DEER CLEANING
I like your idea. Hope to have a chance to try it. Thanks
   / DEER CLEANING #4
CrazyQ,
That is like a method I have seen done...with a golfball and rope. A winch is used on the other end of the rope that just pulls the skin off.
   / DEER CLEANING
Do you use your machine to manipulate deer for gutting??
   / DEER CLEANING #6
Don't use the tractor before field dressing, but I really do after....BobG in VA
   / DEER CLEANING #7
Grab strap.
drive away.
Deer skun.
Only skin down to shoulders (if you are already past the hind legs, whats the point ;)) typo I am sure.
This works very well, keeps hair of the meat too. I have skinned deer with truck, winch, tractor, wifes car:D... hanging the deer and using the tractor to skin is the best. This was the first deer season that I had my new tractor with loader. Skinning with the loader is nice because you can pull down rather that horizontally, easier to stay in control.
   / DEER CLEANING #8
Put deere between two tractors. One geared tractor and one hystat. Now pull in opposite directions. Whichever tractor ends up with the most deer is the better transmission. End of geared vs hydro debate.
Oh, that's another thread. Sorry.
Sincerely, Dirt
   / DEER CLEANING #9
My bucket has a 2" square receiver hitch welded on top center of the bucket. I slide in a 3' piece of square tubing that has a short chain and hook on the end. I loop a rope around the deer neck and over the hook and lift with the bucket. That gets the deer out away from the bucket with plenty of room to hose it out and skin it.
   / DEER CLEANING #10
I drag the deer to where I can get it on the loader -- do the preliminary cuts around the rear end and split the brisket then lift the deer up with the loader and finish field dressing it. It drains well that way. My bucket has brackets welded inside to allow me to use 2x6's as brush carriers -- I have a sort of boom pole rigged that fits in one of the brackets to lift the deer higher than the fel alone would. Since I only have one deer tag, I usually just skin it out by hand (I have always found the various rope tricks and pull methods mentioned above to take about the same amount of time to set up and do :eek:) and leave it on the loader to hang and cool -- this year it did not hang long as it was in danger of freezing by day two:eek:
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
ROLL OFF BOX (A53843)
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
