Scariest Tractor Moment
   / Scariest Tractor Moment #1
farmboy12
Benedict, MD
Kubota M4900 FEL; New Holland TC30 MMM; Ford 1620; Ford 1520 MMM; John Deere X740; John Deere 455 MMM; Craftsman 19.5hp;;;;; Antiques: 1946 John Deere B; 1951 John Deere MT; 1952 Allis Chalmers B; 1967 International 140
What are some of your scariest tractor moments? What crazy things have happened to you during operation of equipment?
This is mine, probably-
-This morning, I was aerating at my school. I was aerating a low part surrounded by hills, on very steep. The one that was steep was the one I had to go up to turn around. I was tired, unaware of what was about to happen. I hit a rut, tipped on to the aerator, bounced, when I came back down I was off-direction, I started going up sideways, nearly tipped but I was able to regain control. I was awake after that!
Kyle
   / Scariest Tractor Moment #2
Confession time.
I had just taken delivery of my new B7100 with FEL (1993) and had not purchased any 3 point attachments yet, so it was rear light. My creek has one of those arched Japanese style bridges across it and I decided to move a fairly large rock in the FEL over the bridge. You guessed it, as I crested the top, the tractor did a face plant and was standing on the FEL and front wheels, back end in the air. :eek: I quickly shut off the engine and looked to see if any one was watching. :eek: I set it down by shutting off the fuel and using the starter motor and hydraulics to ease it back to the ground. What a orientation to my new tractor. :rolleyes:
   / Scariest Tractor Moment #3
Kyle
So far, my scariest happened many years ago when I got my first tractor (JD 755) and was helping a neighbor move some gravel he had delivered. I was pretty comfortable with the whole forward, scoop; back, dump routine and one one trip to dump a bucket full got to a bit steeper part of the yard. The tractor very slowly went up on two wheels and balanced there to the point where I had to jump off and could push it back onto all four while lowering the bucket.
Suffice it to say I wasn't as casual with the rest of that project, nor have I been on any other project since.
Jay
   / Scariest Tractor Moment #4
Went for a ride on a frozen lake one time. I remember thinking it was strange how the cracks kept aiming themselves right between my tires. Left, then right, back and forth.
Got lucky.
Jake
   / Scariest Tractor Moment #5
Confession time for me too.
A couple of months ago, I pushed over a dead locust tree with my L4400. It pushed it down, then the canopy of the tree got caught up in another tree. The tree was at about a 45 degree angle so I backed and went to the side of the tree to give it a push to get the tree untangled from the other tree. As soon as it became untangled, the tree fell over. What had happened, that I couldn't see, the tree had gotten wedged between two teeth on my tooth bar and as soon as the tree went over, with all the leverage of the tree top, it flipped my tractor over on it's side in a hurry. After I shut it off, it took me about 2 hours to get it back up. Adding to all of this, nobody was home, so if it had somehow fell on my leg (had the seat belt on) when it went over, I would have been there for awhile.
   / Scariest Tractor Moment #6
Turned a corner once with a Farmall H and one rear tire came off the ground!:D
   / Scariest Tractor Moment #7
Shortly after I got my tractor, I was picking up rocks from a recently cleared area. I had the bucket full of rocks and was approaching the dump point, which was down a slight incline. I approached perpendicular to the decline, turning down the slope and started to lift the bucket. She got very, very light and I slamed the bucket to the ground to save myself. I was not wearing a seatbelt.
I now where my seatbelt all the time, and always go striaght up or down the slope when loaded.
   / Scariest Tractor Moment #8
JD 350B dozer. I had the blade off the ground, I was on a slight hill. The motor was off and I was working on some electrical connections in the dash. I was standing on track, the gear shift lever was in my way. I threw her into neutral, and she started to roll. I side stepped on the track, otherwise I would've gotten rolled over.
That was by far the scariest moment I've ever had.
Just remembered another one. I was removing my frame mounted hoe on my old Kubota. I had blocked the how with wood but not the front part of the frame under the front of the tractor.
i reached UNDER the hoe to pop out the last bolt and the hoe fell straight down onto my wrist, if not for the blocking on the back of the hoe I would've severed my hand. Instead the front frame part bounced off of my wrist and the ground, I got away with a swollen wrist, cuts and a wrist brace for a couple of weeks. I was very very lucky to not have had my hand severed. The frame was 1/2 inch thick flat rolled stock. The hoe weighed about 700 lbs.
Bottom line, things happen fast and you can never be too safe.
Joel
Another confession for me- none of our experienced family wears a seat belt (me, Pop, Grandpop, and Uncle).
   / Scariest Tractor Moment #10
I was moving a bunch of fill dirt for a neighbor up here on the mountain over the summer. His back yard had a sink hole from where the builder had buried some tree stumps. That hole was about 10 ft deep, 8-10 ft wide and 20 ft long. He had about 16 trucks dump dirt in it over a span of about 4 years. They had been dumping the dirt in his driveway and he would push it down a steep hill into the hole with the snow plow on his 4 wheeler. It was taking him forever so I offered to help with my BX24. Took me 3 weekends to put the dirt in the hole. Any how after most of the dirt had been moved I was finishing up and ran over a soft spot and the tractor went on 2 wheels. I tried to drop the bucket but it was over the hole and the tractor was quickly about to roll sideways down my neighbors yard. I jumped off and held it up by the ROPS and was about to lose it when my neighbor ran over to help. I could barely reach the stick to dump the load but managed to do it. Ever since then I move muuuuch slooower on hills and check for soft spots and rocks. Almost had to change my pants after that one:D.
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
