Cold Weather Grease
   / Cold Weather Grease #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
Actually, it should be "moderately cold weather grease".
It was about 40 degrees F today, and I greased my tractor.
The old grease I wiped off the zercs had the consistency of taffy. Really hard to get it off. The new grease was stiff and hard, but not as bad as the old grease.
Is there a low-temperature grease I should use in winter?
   / Cold Weather Grease #2
Dave,these folks have good products.http://www.schaefferoil.com/products.html
   / Cold Weather Grease #3
I use whatever general purpose, farm and truck, grease that says "all temperature" on the label but others here suggest using only "Moly"
   / Cold Weather Grease #4
There is always something similar to what they use on the space station!
Braycote 602EF is a smooth, buttery, gray colored NLGI #2 grease. The base fluid (Brayco 815Z) is a stable perfluorinated polyether with exceptional chemical resistance, extremely low volatility, and a wide temperature service range. The gelling agent is a tetrafluoroethylene telomer. This grease contains molybdenum disulfide. Braycote 602EF is nonflammable, does not use any chlorofluorocarbons (CFC's) during product manufacture, and is in general, chemically inert. Braycote 602 is an excellent lubricant, has good shear stability, and low acute toxicity.
As with any high performance material, being used in critical applications, one should never contemplate its use without being familiar with its typical properties.
Temperature Range:
-80ー C/-112ー F to +204ー C/399ー F
   / Cold Weather Grease #5
Depending on how cold it gets in the winter you could use a NGLI #1 grease instead of a NGLI #2 grease. It will pump a lot easier in cold weather. Just like oil viscositys there are multiple viscositys available for greases. Most will be available in NGLI ratings as low as #00 and some even lower. Once you get to a NGLI #00 grease you are entering the "semi fluid" range which would remind the average person of gear oil. Another thing to look at in grease specifications when you are shopping is the greases pumpability test rating. The ASTM test standard is ASTM D1092. This test gives you the lowest temp at which the grease still pumps easily out of a manual grease gun. You will find that the low temp operating range of NGLI #2 greases can varry quite a bit from brand to brand. Some will stiffen up while others will maintain their flow properties much better. Most of the greases I handle have a ASTM D1092 rating of -5 to -20 deg. F in the NGLI #2 viscosity.
2014 Freightliner M2 106 Palfinger PK22002EH Knuckleboom Crane Truck (A55973)
2014 Freightliner...
500BBL WHEELED...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
