Only 5 Attachments
   / Only 5 Attachments #41
1- front mount snow blower.
2- Back hoe.
3- rough cut mower.
4- front blade.
5- a plow. I wish they made roll over plows for compacts. Another idea to build one. :)
   / Only 5 Attachments #42
Why assume we have the FEL? That's my highest priority attachment... Ok, here's my others for me JD 2210:
1. some kind of leaf vacuum/rake, etc. to get these millions of leaves up!
2. Pat's Easy Change! I got the Harbor Freight one, but it only works on me rear finishing mower - basically useless because by rear blade, etc., width is different.:(
3. 48" tiller - I think that is the right size for the 2210.
4. back hoe
5. box blade
Nothing a few $$$$s wouldn't solve:D
   / Only 5 Attachments #44
grapple, mower, box blade, rototiller, log spliter
   / Only 5 Attachments #45
Seems to me that '5' makes this a pretty predictable thread. Not to much thought has to go into it really. I only have 5 as it is (including the FEL). I'd like to ad a spreader, or maybe a two row planter but I get by with what I have.
Let's make it interesting. More like one of those desert island questions. Lets make drop it down to two so that people really have to think a bit. And that does NOT include FEL.
So, for my needs, it would be 1) FEL and 2) Rotary cutter. It would be very painful to do without the BB which I think is the most versatile and generally useful attachment there is, but I got the tractor for mowing and the mowing never ends so if its just two, its the mower and the FEL.
   / Only 5 Attachments #47
The Easy Change doesn't count. So you can add another one. Besides, if all you had was it and a front mount snow blower....then you wouldn't need the Easy Change!
Also, I don't mean to hijack. Listing 5 is fine and interesting to see what people choose and use....but listing two is tough and interesting to see what people can't live without.
I'd be very very unhappy without my BB.
   / Only 5 Attachments #48
1 backhoe
2 stump grinder
3 QA front forks
4 QA grappel
5 box blade
Shane
   / Only 5 Attachments #49
1) large heavy duty rear blade
2) backhoe
3) brushhog
4) rotary tiller
5) hay forks (spaced for pallet or bottom lift round bales)
   / Only 5 Attachments #50
id like to say that my choices would change depending on how big (or small) my CUT was.
If i had a MMM or if i had a big class 3 id likely not pick a RFM as an option, but if you had a smaller class 1 or SCUT then id defintly include a RFM if it didnt have a MMM
obviously your not going to choose a disc/harrow as a must have if your tooling around on your riding lawnmower er SCUT. Same goes for a bail spear/bail forks.
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
2006 International A325C 6.0LV8 Turbo Diesel Engine and Transmission (A50325)
2006 International...
23169 (A50324)
23169 (A50324)
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
