Vacume and diesel engines
   / Vacume and diesel engines #31
You misread Soundguy's post. He said NA engines produce lower HP at lower AP (absolute pressure) which occurs at higher altitudes. The most HP is produced at sea level or, in the case of Turbo/super chargers, lower than sea level ( which is a higher AP). Turbos & superchargers make thin air thick. This also works on a cold day in Death Valley for those that think lower than sea level only occurs under water.:cool: Yes - it's counter intuitive. MikeD74T
Actually, I read Soundguy's post right, I just botched it when I replied. Thanks for the correction.
   / Vacume and diesel engines #32
So---- would the plane take off??????
   / Vacume and diesel engines #33
"So---- would the plane take off??????"
Don't know, but check out how many successful WWII piston-engine aircraft had turbochargers, turbo-superchargers or superchargers.... If they didn't have the boost, they didn't last long at higher altitudes against those that did....:(
   / Vacume and diesel engines #34
Sounds like we are getting ready to reopen this old thread again.
You go first!:)
   / Vacume and diesel engines #35
Thats an old question ! Myth Busters proved it would take off with no problem.
The plane would take off of it had a 50mpg tractor engine.
Bill
   / Vacume and diesel engines #38
With a HST, when you pull the stick back does the plane go backwards too?
   / Vacume and diesel engines #40
I can't tell from the picture does that plane have R1's, or R4's?
Adams 8 Ton Weigh Hopper (A53473)
Adams 8 Ton Weigh...
2016 CAT TL642C (A50123)
2016 CAT TL642C...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
