Almost hate to do it to you, but....?
   / Almost hate to do it to you, but....? #21
The extra pressure may have been 7 to 10 psi more then standard settings. and the tire size may have been 2 sizes bigger, I forget. i know it was hard to get on but they would stay.
   / Almost hate to do it to you, but....? #22
That sounds like a really unique soluition. I guess your father had a ready source of larger tires and also had 2wd tractors. That large change in circumference on a 4wd tractor would surely cause some driveline stress. I guess I should also ask if this was fronts only or did he do it on the rears also? If it was rears, I can see why they were such a struggle to mount. They could also cause clearance issues, it seems.
EDIT: Duh! Just reread your post that it was 2wd and fronts only. I'd love to see a picture of that.
   / Almost hate to do it to you, but....? #23
Slime, Slime, Slime
This is just another one of those products that work for some people, and not for others. In my opinion, with a tire that has never had liquid in it and the right amount of Slime, it almost has to work. It will put a thick coat all over the tire and wheel. I worked in landscaping for 22 years, and it worked very well in my situation. I have also used oil on the bead to soften the rubber, and tire bead sealant. They say to not plug and Slime, but I have done it. It is best to buy in 5 gal bucket, it is much cheaper. I wished they would bring back the old hot patches. Vulcanization is the best patch where you melt rubber to rubber.
There is no way that Slime will work on a filled tire because the amount of filled solution to the quantity of Slime is to great. If it has worked for some, I suggest it is pure luck
   / Almost hate to do it to you, but....? #24
My dad used to, on a 2 wd dexta front tires take 2 used tires next size up and cut the beads out and slip those over the mounted tire, A tire over a tire and increase the pressure to keep it on tight. it was a ***** getting on but work very well.
Has anyone ever done or saw this done?
Clever idea! One might even cut the sidewalls off a smaller tire & put it inside, maybe thorns would'nt go thru both & the tube would be protected ??? MikeD74T
   / Almost hate to do it to you, but....? #25
yes it could be done i suppose similar to a boot in a tire
   / Almost hate to do it to you, but....? #26
Slime, Slime, Slime
I had a tire shop fix a car tire once He had a patch that looked like a vulcanizing tire patch with a plug on it. He also applied it like a vulcanizing patch. I thought that was the best of both worlds.
   / Almost hate to do it to you, but....? #27
Slime, Slime, Slime
Now there's an idea... load the tire WITH slime! weight , fluid, and puncture resistance...
soundguy
   / Almost hate to do it to you, but....? #29
Ever see the cost of beet juice.... bring your loan application!
soundguy
   / Almost hate to do it to you, but....? #30
Isn't that what the ice bikers always do?
2018 John Deere 645FD Flex Draper Head (A50657)
2018 John Deere...
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
