Oil & Fuel Torque fuel inyectors.yanmar 186 diesel.
   / Torque fuel inyectors.yanmar 186 diesel. #1
cgmz77
Winter Haven,FL.
Yanmar 186,shibaura 1540, Lo-boy,
I have to take the fuel injectors out for cleaning and check. What is the torque for nuts/bolt to put them back? Another question,How you chek the compression in the engine?
Tanks. cgmz77
   / Torque fuel inyectors.yanmar 186 diesel. #2
Can't help with the torque question but I think there are brass washers under the injectors that you will need to replace if you pull the injectors out, might want to get them before you pull them out.
   / Torque fuel inyectors.yanmar 186 diesel. #3
Tanks. cgmz77
The torque for the fuel valve holders is 29-33 ft lbs. Your not going to have much luck cleaning this type nozzle, replace them.
Danny
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
