Tractor Storage Woes
   / Tractor Storage Woes #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Metal-pole and canvas buildings make for great tractor storage sheds. They aren't terrific at handling snow loads, and do disintegrate when you accidentally run them over, however. It did well last winter, but took a few solid shots from the bucket this past year, so it was getting pretty rickety and was fairly crooked. I planned to sure it up before the snow came, but never got around to it. Also, after last week's double 10+ inch hit, I completely forgot to knock the snow off with a broom...oops.
Wouldn't have been so bad, except for the 30,000 pounds of snow on top of everything. Who would've guessed I had to actually cut the tractor out with a utility knife. Sheesh.
Check out the 500# chunk of frozen gravel that was stuck to my B/H bucket. Even a couple of wacks with a sledge wouldn't budge it. It'll fall off sometime before spring.
Finally, after about an hour and a half, my Kubota was free, and the tent was off to the tractor-storage yard in the sky.
I hate when that happens...
JayC
   / Tractor Storage Woes #2
did you junk the frame too?
Wayne
No - I haven't junked anything yet, it's still just in a pile. I'll probably try to use the tent sides to cover my tractor up this winter, and I might try to rig some kind of cover frame with the remaining tubing. I'll keep it kicking around in a pile in any case - I'm sure I can think of something fun to weld up using all of that tubing.
JayC
   / Tractor Storage Woes #4
Well its pretty obvious what your spring project will be, you're going to build a proper shed for your tractor, right?
   / Tractor Storage Woes #5
Wow! I can sympathize with you. Mine came down with the ice storm we had here a few weeks ago. I have decided to replace it with a shed with wood sides and roof. Of course it will be bigger than I need. (If I can convince the wife)
   / Tractor Storage Woes #6
No it won't .
In fact it will be to small no matter how big you build it.
I was thinking of putting up a pole-barn type of thing w/o walls. Just a suspended roof - that should do the job nicely.
Even better was this past fall, when I hooked the corner of the shed (the one in the pictures) with the fender of my equipment trailer at about 20MPH, and tore the entire front wall (doors and all) off of the shed. I could see EVERYTHING in the shed - almost gave myself a hernia laughing. You can see the broken vinyl corner piece where the trailer punched through in the first picture. Good thing I'm a better carpenter than a tandem driver.
JayC
   / Tractor Storage Woes #9
Thats the first and last thing I check after a heavy snow..My canvas shed...
Made sure to get the heavy snow off before tha last rain...Of course I stacked wood and pallets too close so all the snow fell down and in between the two, so here i was wading thru 4 foot snow pushing it out with my hands so the sides wouldn't implode....
For future shed builders out there, I built a 2 x 6 PT frame for all the leg bases to be screwed to, and also holds in the gravel quite nicely...
BTW jay4200, what brand? I have a shelter logic with the standard 9oz cover. remarkably strong I thought....
although runnning into it I'm sure didn't help.... I treat mine like a newborn baby, pulling in and out of the shed, as I don't want to be in your position
Good luck with the new one.
   / Tractor Storage Woes #10
I built mine two stories to justify the construction. It has a playhouse for the Grands and young kids upstairs. Course I'm going to have to build steps or something one day so they can get up in it except by ladder. Want to build a deck on one side to make a cover for implements and then have steps up to deck..
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2014 Gleaner 3000-R8 Corn Head (A50657)
2014 Gleaner...
