Cammond 5ft hydraulic box blade - How much?
   / Cammond 5ft hydraulic box blade - How much? #1
myyaz33
Nebraska
TYM T273
USED: Cammond 5ft hydraulic box blade - How much?
How much would you expect to pay for a used Cammond 5ft Hydraulic ripper box blade? I believe it is their standard version. I am looking to make an offer on it and not even sure where to start.
   / Cammond 5ft hydraulic box blade - How much? #2
Re: USED: Cammond 5ft hydraulic box blade - How much?
The BS/H model looks like a pretty simple design--a standard looking BB with a small hydraulic cylinder to operate the rippers. A 5ft KK BB without hydaulics at TSC runs $500 new. Add say $150 for the hydraulics and that Cammond is worth $650 new-IMHO. Used--$400. Offer $300 and see what happens.
   / Cammond 5ft hydraulic box blade - How much? #3
Aren't the Cammond's much heavier duty than a KK? I've seen a few for sale around here used. All were a $1000 or more.
   / Cammond 5ft hydraulic box blade - How much? #4
415lb for the KK, about 500lb for the Cammond
Thanks for the input on pricing. I too was under the impression that this model was heavier duty than that of a king kutter. Will try negotiating tonight.
   / Cammond 5ft hydraulic box blade - How much? #6
I just haven't seen the Cammonds around here except for one on a rental Kubota and it was a much, much heavier duty box blade than anything KK makes. So, I'm guessing a used Cammond would be worth more than any new KK. (You'll notice I said I'm "guessing"; don't know for sure).
   / Cammond 5ft hydraulic box blade - How much? #7
85 lbs of reinforcement gussets, thicker sides, etc. can make all the difference.
   / Cammond 5ft hydraulic box blade - How much? #8
Yep, you're right. Question is how much is 85 lb of steel worth in this case. That's up to the OP.
The fella wanted $500 and I just can't do it right now. Might be able to make him a respectable offer in a couple of weeks.
   / Cammond 5ft hydraulic box blade - How much? #10
My local used tractor dealer has a 6' one for $500.
REAR 3
I've thought about getting rear remotes and buying it.
2004 Mack CV713 Granite Fuel and Lube Truck (A51692)
2004 Mack CV713...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
