Oil & Fuel Are Mahindras oil burners?
   / Are Mahindras oil burners? #1
Kirby Nance
Marine, Illinois
1952 8N and 2008 Mahindra 4025
I was reading jasperab's problems on another thread and many replies asked if he had checked his fluids prior to the 186 hr failure point.
I just bought a new 4025 so I thought the better part of wisdom might be to ask if there is something in these remarks. Do these things burn oil normally? I don't mind doing a preflight on my tractor(always have), should I be looking to add oil regularly?
Kirby Nance
   / Are Mahindras oil burners? #2
Kirby Nance
Mine didn't use oil - 328 rough hours.
   / Are Mahindras oil burners? #3
My 3215 with 111 hours has not burned any oil.
   / Are Mahindras oil burners? #4
2615...no oil issues. Don't you think that 1 in xyz GMC, Ford, Yamaha, etc. or any other manufacturer may have a defect here and there? Probably so. I'm sure the the other forums have stories about the 'other' tractors. Just my .02.
   / Are Mahindras oil burners? #5
Kirby Nance
I've been a Mahindra dealer for 7 years and have not had one complaint about oil usage.
   / Are Mahindras oil burners? #6
Just follow your run in procedure and you will have no problems with oil usage. If you don't put the engine under "pressure" though your rings will not seat properly. In other words work it! 300 hrs/no oil usage.....BobG in VA
Thanks for the replies, folks.
Those are comforting answers.
Kirby
   / Are Mahindras oil burners? #10
Model 3510 w/around 550 hours - No oil use.
Rusty
Farmall A Tractor w/Belly Mower (AS IS) (A50774)
Farmall A Tractor...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
LOT LOCATIONS (A52576)
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
