Whole House Water Treatment
   / Whole House Water Treatment #1
GarthH
Saskatoon, Saskatchewan
Hope the new year comes with a better economy than last.
I recent ran our water through an analysis, during the time I had not used the softner for about a month.
Our TDS (total dissolved solids calculated) came in at 600 - max recommended is 500. No other category was listed as high including the hardness was in the mid range.
I looked on Wikepedia and saw the only method for a home owner to bring down the TDS is Reverse osmosis. We don't use our house water for drinking although we do cook with it. I notice the cost of RO is quite high on a small scale; does the cost remain high if you get a larger system? I'm thinking about 5 to 10 gallons per hour.
I'm trying to figure out what I can do to bring the TDS number down. I started to wonder about setting up a couple tanks to pre-prepare a volume of water - 300 gallons. We would draw out of the tanks rather than directly from the well.
Is there sometype of treatment that I could do for pennies a 100 gallons that would improve the water?
Thanks all.
Garth
   / Whole House Water Treatment #2
I recent ran our water through an analysis, during the time I had not used the softener for about a month.
Garth, what are you treating? The number or some end user concern with perceived quality?
If you water is fine, then why bother?
Bob
   / Whole House Water Treatment #3
We have the whole house on filter (5 microns) to keep the red virginia stsain out of our water. Works well, just needs replacement evry 2 month or so.
   / Whole House Water Treatment #4
I had TDS 900 plus and nothing else to stop us from drinking. My solution for under $1,000 for total project.
1. Sand filter, whole house
2. Water softner, everything but outdoor faucets
3. Under kitchen sink five stage RO with booster pump and storage tank. This water used for all cooking and drinking
4. TDS meter
After one year and one new set of filters TDS still under 50
Only unfinished part of project is to dump RO flush water into a storage tank (now into septic) for plant watering and maybe wild animal drinking.
   / Whole House Water Treatment #5
My well water has a TDS in excess of 1,000, in addition to many other issues. After extensive research, and trial and error, my understanding is that RO is the only way of lowering TDS. Since the solids are disolved, they are difficult to remove otherwise. Even with the high TDS, it really doesn't pose a problem, since I remove the sulfur and use a softener.
   / Whole House Water Treatment #7
"1. Sand filter, whole house" can you describe your sand filter or maybe a picture?
i have one but am always looking for a better way to do it.
heehaw
   / Whole House Water Treatment #8
Czech,
We have high iron in are water (oranage stain)
Your saying a filter took care of it for you ?
Thanks,
Nick
   / Whole House Water Treatment #9
the high iron/orange staining, is why we have a sand filter: also takes out the sulfur smell.
heehaw
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
UNUSED INDUSTRIAS AMERICA L5 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
GOOSENECK COUPLER (A51248)
GOOSENECK COUPLER...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
HURRICANE 40' CONTAINER (A51248)
HURRICANE 40'...
