Chain saw "mills"?
   / Chain saw "mills"? #11
Cutting your own wood for above-ground purposes is great - I love working with rough-cut. But for ground contact I would just buy quality treated posts and be done with it. Trying to fabricate your own chemical bath is both hazardous and unproductive compared to the cost of buying a couple of posts.
Mike
   / Chain saw "mills"? #12
This time last year I was doing a lot of chain saw milling. I was using a Logosol M7 if I remember correctly.
I cut a ton of wood with it. I made siding, framing lumber, and some other stuff. I think you can find it doing a search for "this, that, and the other" and my name.
   / Chain saw "mills"? #13
Chain saw mills take a LOT of power to do anything useful, you are probably looking at power heads in the $1500+ price bracket.
Yes, that is PLURAL power heads. For any worthwhile production it is a double ended bar with a head at each end.
Bars aren't cheap either, it is HARD dirty work at ground level (how's your back ?) with 2 stroke fumes.
I have a portable mill, it is a swing blade type.
Oh, sure the kerf is a bit wider, but the cut is straighter so there is less loss when planing to compensate for wavy blades and a 26 inch diameter carbide tipped blade lasts a lot longer than a band & is quicker/easier to sharpen anyway.
Re knots and nails;
Know the height at which most humans can pound a nail into a tree for hanging bird houses, yard sale signs, whatever, also screw eyes for things like clothes lines. That will take care of 95+% of the metal you are likely to find. Check for rust streaks too.
Slow down for crotch and knot areas, you should see them coming (-:
This is where band mills REALLY go weird and wavy.
For ONE project such as a barn, if you have enough standing timber get someone in with a portable mill, you can probably get all your rough cut milling done on a deal whereby he takes away the same amount he leaves - you get to keep his bark and wane edge too.
   / Chain saw "mills"? #14
My chainsaw mill has a double ended bar, used a Stihl 076 on each end, and will make beams up to 16x34. I use it with skip tooth ripping chain and when sharp it leaves a pretty decent finish (rough, but can be planed out smooth in about 3/16")
for example: a buddy and I cut up a large white oak one afternoon into boards - 2 at true 4x28 x11' with the intent of making rafters, and 29 at 2" thick that i have used to make stair treads, a breakfast bar, etc... and still have plenty left to play with.
I got it used for less than $1000.
bandsaw mills start around $3000.
I figured the lower output and doubling my effort was worth the cost difference for my occasional use.
Thanks for your ideas guys. I'm thinking I'll buy treated posts.
Still going to keep an eye out for a good used mill, maybe make some above ground lumber.
Thanks, Tim
   / Chain saw "mills"? #17
Thanks, Tim
I bought a simple one that uses a straight 2x6 that is used as a guide to keep the chainsaw straight. There are all sorts of other ways to keep it straight, and most are allot better then what I bought. Mine does the job, but it's never going to get a perfectly straight cut. Again, here is where you get what you pay for.
I've made beams for my ceiling in my house and my coffee table with the lumber that I cut with mine. It's tiring, noisy, dusty work. It is WORK!!! The longer the cut, the more you wish you were not there.
I used a standard chain for this and wish I had bought a couple ripping chains. That would make a big difference from what I've read. Next time for sure!!!
Buying Pressure Treated posts for your shop is the smart way to go. You won't save any money by cutting them yourself. Cutting lumber yourself is only a good idea for small projects and having fun. Not for building anything. Lumber is too cheap for it to be economical to cut it yourself.
Eddie
   / Chain saw "mills"? #18
I have a Alaskan 36" mill. I cut some slabs with it and it works very well. The hardest part is getting the first cut level. I used an aluminum ladder for the rails so I could make a smooth, level first cut. I was slicing a 16 foot 18" diamter at about 3 to 4 minutes a slab with a chisel chain. I have a rip chain for my 36 inch bar but haven't used it yet.
   / Chain saw "mills"? #19
I've helped a friend with a bandsaw mill, but have no hands on experience with a chain saw mill.
Would you please explain how you make the cuts? It looks like you've added something to your ladder, and I wondered why you restacked the cut boards with spacers.
   / Chain saw "mills"? #20
I've used a 36" Granberg mill for about 20 years to cut hardwood into boards for furniture use. I run it with a Stihl090.It is very dusty, dirty work and hard on the back since I tended to cut thick slabs to avoid turning half the log into sawdust. If everything is working right you can cut clean straight boards.
If cutting these pines is a one time deal IMO you would be better off hiring a guy with a bandmill. But if you can make good use of a larger chainsaw for firewood or more log milling down the road that would also be a good option. In either case make sure you properly stack and cover your lumber while it is drying. Also make sure the boards are at least a foot longer than the final dimensions.
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
