Prices Kubota JD Kioti 30+ HP which one is a good deal
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #1
Polly
Here's the numbers:
New L3240HST Tractor, hydrostatic drive, 4wd, diesel, folding rops, R4 industrial tires, tilt steering wheel, telescoping draft links, arm rests, open platform $16,119
New LA724 loader installed with quick-attach bracket, 72" quick-attach bucket, fluid in rear tires for ballast $4,808
New Landpride BB1572, 72" Boxscraper = $976
Total Package = $21,903
New Kubota L3400HST1-F Tractor, hydrostatic drive, 4wd, diesel,
folding rops, R4 industrial tires = $14,589
New LA463 loader installed with 60" pin-on bucket, fluid in rear tires for ballast = $3,917
New Landpride BB1560 60" boxscraper = $798 Total Package = $19,304
or Kioti DK35SE HST is a hydrostat transmission tractorwith Industrial tires and with a KL351 loader. The loader is good for 1412lb atthe pivot pins while the 3-point is rated at 2383lb 24 aft of the hitch. This tractor has a 38hp diesel engine and is loaded with features including 4x4shifting with locking differentials and is designed to be a top notch tractorwith a mid-level price. Price: $20,000 and has a $900 rebate available if a cash deal is made.
or
John Deere PRICE ON A 3032E (31.4HP) MFWD LOADER AND BOX SCRAPER
BE $16800.00.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #2
I will speak for the Kubota models only. I have spent a week or a little more looking at the Grand L models so I think I can easily look at the other models they have to offer and speak of some pluses and minuses.
The L3240 has much high weight capacities. For me this would be a major point to look at a it. Also the lever which runs the FEL is mounted closer to the user on the L3240 which may be a consideration for you. The L3240 does have 3 less HP. I am not sure if this makes a difference for your use. The L3540 has a very similar HP rating as the L3400.
I just double checked the specs. I have not used a L3400 nor did I test drive one to see it's advantages. I would recommend the L3240 of the two Kubota models (with a price check on the L3540).
I chose the L4240HST on order and it should be in next week. My current tractor is very close to the L3240, but the HST is much nicer. The larger loader for the L3240 is much better than mine.
Also consider dealer support. I learned this is very important. Don't look at the dealer that can support you know with a little lower price. Look at the dealer which more than likely will provide great after sales support for the life of the machine. I received a great price on my current machine. The dealer is not supporting these machines well now (no longer carries line and does not have a tech and parts on hand). I received excellent support to fix my recent problem from my Kubota dealer without hesitation. I am trading it for a Kubota now.
Good Luck,
Mike
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #3
Where are you located?
In June-July a DK45SE HST with FEL was ~21000 in Central Texas.
Jeff
Here's the numbers:
or
BE $16800.00.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #4
And the DK40/45 has a much stronger loader than the DK35.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #5
Makes the 3240 look like a bargin!
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #6
The extra money for the L3240HST over L3400HST is worth it. I would not recommend the L3400/2800 to anyone.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #7
I think you've gotten your answer on the tractors.
If you go with the Landpride Box Scraper, I think you need to go with the 25 series. Those machines might tear up the lighter duty 15 series, especially given that Landpride recommends 17-25 hp for the 15 series and 25-40 hp for the 25 series.
I've run a 15 series box scraper on a 30 hp Kubota, and wouldn't run anything less than a 25 series on a machine the size & power of the ones you are considering.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #8
The DK40se is the sweet spot in the Kioti line right now. Much more powerful loader than the DK35se as well as bigger axles and tires for not a lot more money. Only difference between the DK40se and DK45se is 4hp and about $2k (last I checked).
Love my DK40se.:) (not the tractor in my avatar...that is the CK20)
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #9
Ditto on the Kioti DK40SE,I love mine.coobie
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #10
From a price / value perspective it is really hard to beat the DK40SE with the 401 loader. That loader seems like a BEAST.
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
