3 Pt. Won't Lift (-20C)
   / 3 Pt. Won't Lift (-20C) #1
MEJ
I've got an older (probably 25 Yrs old) 13.5 hp Yanmar that I kind of inherited. It doesnt do a lot of work on our farm except a bit of rototilling and a bit of snowblowing. (probably less than 20 hrs/yr) Because of this and its trouble free nature its been neglected a bit in the maintenance dept. Now suddenly the 3 pt is not lifting the snoblower. So I tried to check the oil in the back end. There's a yellow cap under the seat to add oil but no dip stick. Not sure how you check the level. I tried adding a little oil to see if that would make a difference. It didnt. Is there some sort of screen in the hydraulic system? I dont think its suddenly low as it s never leaked. It was quite cold (-20C) when I tried it. But I tried it again after it had been in a building overnite that was 0C and it didnt work. Not sure where to start on this hyd. system. Obviously I dont have a manual. Thanks.
   / 3 Pt. Won't Lift (-20C) #2
What is the model #
Danny
   / 3 Pt. Won't Lift (-20C) #3
It could be low on oil, but more than likely it has moisture plugging the filter, If you have a YM135, the hydraulic screen is behind where the suction line attaches.
Model # is YM 135D
   / 3 Pt. Won't Lift (-20C) #5
the dipstick is (if its the same as mine) on the left of the seat, on top of the axle - small 1/2" diameter rubber cap.
   / 3 Pt. Won't Lift (-20C) #6
I find in real cold weather that the hyd. oil needs to heat up a bit before the FEL and the rear lift arms will work at good speed. Some food for thought.
Also, does this model have a dip stick rod on it to show the correct level of fluid in the sump? Is it missing?
Dick
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
