I Had No Idea It Would Cost This Much!
   / I Had No Idea It Would Cost This Much! #51
A 60 hp trctor should be a good size for your place. I am considering replaceing my older utility 820 with a 4720. Just make sure you get the extra features you need, details like telescopic draft links make hitching up much easier ect. not everything works with the new hitches.
I also have a 110 tlb with the Laurin cab and when clearing and cleaning up brushpiles have found that the rail mount forks do a great job of moving the piles. The forks will slide beneath the branches and stumps much easier than a bucket will and will allow the dirt to fall back on the ground.
Just my opinion but for clearing I would rather use an older tractor rather than a new one, and prefer the 110 for backhoe and loader work. Since loader work is the main reason for having a hydro transmission lots of to and fro movement and I have all of that on the 110 tlb a much simpler tractor wll handle most of the other chores. My 38 hp 820 with canopy (1975) is in excellent condition with about 1200 hrs and handles most of the other jobs quite well. I read posts like your's though and think it might be better to keep it and preserve the newer tractor for working in the open spaces.
To sum it up if I were looking to buy just one tractor for everything I think the 4720 is just right. I would plan on having some weights on hand to increase the bulk of it too.
Steve
   / I Had No Idea It Would Cost This Much! #52
The more I get to know this tractor the more I agree. At first I found the power tricky to handle on a relatively small tractor but didn't take me long to realize I couldn't have found a better machine for the purpose, in my case commercial snow removal. Does everything a full-size with similar power does, but can go where a full-size can't. Road handling takes some getting used to though, short and narrow vehicle means both hands on the steering wheel lol
   / I Had No Idea It Would Cost This Much! #53
So I'm going to close on the Farm--100 acres with 25 of them cleared for pasture. I would like to clear some of the woods...
So I need a tractor -- but geez!
You would think i'm getting gold plated stuff here...but this is what i'm quoted:
JD 5105M $55188.95
FEL 563 farm loader 6500.00
PHD with 9" auger 2700.00
Box Blade Long Grapple Bucket 78"-->$3000.00
PC1072 Field Cultivator-->$743.00
709 Rotary Cutter --->$5378.81
73,509 plus tax.........
I think I should price out the KIOTI?
HELP!:eek:
Compare to an equally sized Kubota. They are real nice too.
   / I Had No Idea It Would Cost This Much! #54
I'm sure happy with mine too. I think if I was doing more field work - cutting & baling, etc, I'd want a 5000 series.. For my show (tilling, mowing, snow removal, moving rounds, fertilizing, spraying, moving dirt/gravel, basic landscaping, etc) the 4720 is great. Darin Divinia has experience with both 4720 and 4520 and he says that the 4520 is better value, because the extra power of a 4720 isn't really necessary and the 4520 is 3500$ cheaper.
-Jer.
   / I Had No Idea It Would Cost This Much! #55
-Jer.
For that size property I would go 5000. 4520 is handy, but the 5525 has way more umph on projects. Maybe look for a 5x25 tractor or a newer E series. The Es are way cheaper than the M.
I suspect you already bought something. Which way did you go?
D.
   / I Had No Idea It Would Cost This Much! #56
Wow... The Kubota RTV with heated and air conditioned cab is less that that.
That's for sure....and it's MUCH nicer. My uncle bought one with AC and a hyd tilt/lift plow blade for a LOT less than $17,000
New Holland 489 Haybine (A50774)
New Holland 489...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52128)
LIKE NEW 2023...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
RIGID TOOLBOX (A52472)
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
