What's the smallest practical HP/Tractor you'd consider?
   / What's the smallest practical HP/Tractor you'd consider? #1
63DH8
Gold Member
Parkland,Washington State, U.S.A.
Massey Ferguson GC1725M Bolens TX 1504 (G154) 1957 John Deere 420C crawler
I'm looking for one to use a hay spear, scoop cattle manure, and pulling farm implements with on 100+ acres of land. I have a small (15hp) tractor, but I've discovered it's not enough for some dirty deeds.
   / What's the smallest practical HP/Tractor you'd consider? #2
Depends...but I would favor a 50+ HP outfit w/ or w/o 4WD and a loader- that's up to you. I feel you have way too much property for a 15HP tractor- but it depends on how your 100 acres is laid out. 99 acres of timber? 99 acres row crop? pasture? you get the idea....
   / What's the smallest practical HP/Tractor you'd consider? #4
What kind of farm implements? Are you plowing/planting any of the land?
   / What's the smallest practical HP/Tractor you'd consider? #6
For years, I farmed over 200 acres with 60 HP as my biggest tractor. It was plenty. I tend to 45 acres now with 47hp. Plenty..... I grew up on a farm of 277 acres with 32hp as the biggest. Plenty of power. All depends on how fast you want to get things done, and to a certain extent, the type of equipment you plan on using with the tractor. I've got a 27hp tractor here now I bought to re-sell. After using it for a few months, I've come to the conclusion I'd never get anything done if it was all I had to work with.
   / What's the smallest practical HP/Tractor you'd consider? #7
I used a 1952 8N to maintain a 50 acre horse farm. I did this for about 3 years. I then bought a JD 5103 but still use the 8N for lite work. The 8N did just fine w/ a 4ft bushhog and occasional discing.
   / What's the smallest practical HP/Tractor you'd consider? #8
I think to carry the hay (if its big bales) you are going to need a tractor that weighs a bit more....and that could be your limiting factor. Like others have said...depends on the other implements...but....I would think a starting point would be to look at 35 to 45 hp tractor with a front end loader, weighing at 4000 lbs or more. JMO
   / What's the smallest practical HP/Tractor you'd consider? #9
i can lift a round bail on the 3pt of my class 2 (33hp) CUT. The bucket is big enough to make quickish work of manure scooping but small enough to still maneuver in tight spots (only 5' bucket)
TO lift a 1000-1200 lb round bail on a front fork your gonna need a Class 3 CUT or some old iron. NH makes a class 3 TC34 (34 hp... dont know what the "new" number is)
as for pulling farm impliments it depends on how big they are and what they are. Class 3 is as about as small as your gonna get for use with "small" haying equiment... rakes, discbines, bailers etc 5hp per foot is a good rule of thumb for ground engaging implements (discs, harrows, feild culitvators) and for brush hogs.
you could do some of the chore work with a small class 3 CUT but most of the guys around my neck of the woods that both farm a few hundred acers and keep cows usually have a "primary" tractor in the 75h-100hp MFWD AG which they use for just about everything. (although they may keep a small bobcat around for stall cleaning and stuff)
   / What's the smallest practical HP/Tractor you'd consider? #10
100 acres is quite a hunk of real estate.
I have only 10 acres of flat pasture land and convinced myself that I need a big tractor. So now I have a 2008 Mahindra 5525 (54 hp engine, 45 hp pto 2WD, partial constant mesh tranny) with the ML250 FEL (6-ft wide bucket, about 3000 lb lift capabiltiy at the bucket pins). Cost: $17K give or take.
I'll use the 5525 to pull a 13-ft wide wheel disc cut down to about 10-ft wide to till my hayfield and pull the Massey Ferguson MF-124 two-twine small square baler.
I have a 1964 MF-135 diesel (45 hp engine, 37 hp pto) to handle my JD350 side delivery rake and a 1951 Farmall Super A (19 hp pto) to pull the Minneapolis-Moline P3-6 grain drill (10 ft wide, 20 drops, 6" row spacing).
Something like the 5525 or the Mahindra 6025 (which has a full constant mesh tranny) might satisfy your needs.
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
Detroit pump (A53117)
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
