Toro verses honda snowblower
   / Toro verses honda snowblower #11
I don't have any links to back that up, but it has been known for some time that all Toro lawn tractors other than the Wheel Horse Classic are built under contract by MTD. Their similarites (nearly identical) to Cub Cadet models show this. I'm only presuming it with the snow blowers, but it's a safe presumption because the Toro blowers are not the tanks they used to be and short of having Tecumseh engines look like clones of other blowers that MTD builds. When looking at them in stores, it's fairly easy to tell. For instance the blowers made under the John Deere name look exactly the same as ones sold as Simplicity or Snapper, the latter two companies now owned by Briggs and Stratton. You can't buy anything any longer trusting a name, because a lot of the good old names in lawn and garden equipment are just something else hiding behind that name. A lot of us are called out on this, and it's hard to point to anything published that outright tells who builds what because neither MTD nor whom they build equipment under contract for are forced to reveal this information and rarely ever do- they protect each other because they want to do business with each other.
I never knew MTD made anything under the Craftsman name until I actually bought a weed wacker from Sears last spring. When I ordered a repacement head for it to have on hand, the part arrived in a nice sealed MTD bag. Surprise-surprise, they fooled even me.
I can't knock MTD too much though. One of their snow blower models in the 5-7 HP class was ranked right on top with Ariens in Consumer Guide. In that same test, the Honda model received 4 of 5 stars. It was only knocked down a star because they have a value category, and the model was stated to be too expensive but otherwise a top performer.
-Fordlords-
   / Toro verses honda snowblower #12
I've had a Honda HS624 for about 10 years now and it is unbelieveable! The quality and engineering are bar none. They are expensive, but in my opinion worth every penny. I got mine second hand at a yard sale ($ 800.00) from a guy who purchased it two years prior and sold his house to move into a condo. I think it cost $ 1,800.00 new at the time.
I change the plug and oil every season and maintain all else as needed. This year I started using full synthetic (5W30) and use seafoam as my gas treatment/stabilizer (used to use Stabile). One pull and it starts every time. It still looks as good as the hot summer day I bought it - one of the best investments I've ever made.
I live in Northeastern Massachusetts and we typically see 6" - 2' snowfalls on a regular basis. Winters start in November and usually don't end til about April.
You've made a wise choice.
Best of luck!
Best of luck!
I am looking at buying used honda model 622 snowblower
track drive for $600.I think honda makes one heck of a product line.coobie
   / Toro verses honda snowblower #14
I have the 622 with tracks, and 110VAC electric start. It is about 8 years old and has performed great. It's due for a carb cleaning; running a bit lean, needs some choke even when hot. But that's it other than oil changes each Spring and 2 spark plugs.
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Schwing 750-15 Concrete Pump (A51573)
Schwing 750-15...
