Screw Head Bits
   / Screw Head Bits #21
torx and roberson are great if starting a new project. otherwise, 99% of what you'll encounter is phillips.
i find, as others have posted, that using the correct size phillips head (usually #2 for lumber type projects) is most of the battle. then using a bit which is the right length is the next important thing. (the short ones are often too short to get into tight places and you need to be comfortable to get the correct angle and force applied to the head of the screw.)
i try to buy bits on sale and keep several of each size on hand. and, while it is annoying to break a bit, it is often preferable to stripping out a screw head that is counter sunk and you can't get loose. i would sometimes prefer to have the bit break first. then adjust the clutch incrementally and try again.
i'll also chime in a vote for regular, old fashioned hex head self tappers. rarely do they strip, you can get them in different sizes and probably already have good quality hex head sockets you can chuck up in any drill with the right adaptor. if i don't need to countersink or flush sink, i'll usually go for a hex head over any of the other options.
amp
   / Screw Head Bits #22
Iremember the day when drywall screws were came out.Iused them for everything,thought they were better then chunky peanut butter:D Ialso remember when metal roofing screws first came out.Istill have 1/2 my house done with the old fashion nails.The ALUMINUIM roofing also came in 4 ft wide sheets then,they switched to 3 foot sheets.Idont even know if its available now.Back to topic:D:Now the only thing i use are torx.We call them riser screws[dont know why]Also the larger diameter ones we call riser lags.They are super strong,and will suck down a bowed peice of lumber easily.They are pricy ,but super strong and totally reusable
.ALAN
   / Screw Head Bits #23
SteelDust,
I spent a couple of hours searching for the product you mentioned.
I could not find out anythng for a coated deck screw with a TORX head, however I did find it in stainless steel. Lowes is now carrying the Grip-Rite brand. Can you find a link or picture of this screw. There is another screw head out now called a LOX head. It looks like this, and has 8 sides.
   / Screw Head Bits #24
I have used the Grip-Rite coated TORKs deck screws on my deck. They worked out really well did not strip any out. Bought them at Lowes.
   / Screw Head Bits #25
Almost everything that you ever wanted to know about most common (slot, phillips, and robertson) screw heads their history and evolution can be found here (interesting if your into that sort of thing) When a Phillips is not a Phillips!
SteelDust from your post it sounds like Phillips and Home Depot (Deck MAte) had a falling out. But it looks like HD is still using the Phillips ACR heads? ( at least according to the Deck Mate site)
Personally i like Genuine Robertson bits and screws. A true Robertson bit should be able to hold a robertson screw at any angle. Ive noticed however, that Robertson has started manufacturing their bits and screws overseas and the quality has slipped.:mad:. So i now use generic "square drive" bits.
The only screws ive seen that have Torx heads have been Spax Made in Germany, but theyre $$$. Id love to find Torx deck screws for a reasonable price locally. I wonder if the reason Torx hasnt taken off in carpentry is due to the patent on the Torx head? I know in automotive applications the Torx can take alot of torque and will stay on your screwdriver like a Robertson,
   / Screw Head Bits #26
J_J
The deck mate screws sold at Home depot now are definitely torx drive, that's what I was complaining about in post #16, I think that letter explains why now (thanks steel dust). I personally don't like them but I dislike Lowes even more, so I'll have to get used to them, or pick up a few boxes when I'm forced to go to lowes for something else. Like I said those blue tip/ phillip square driv were great, IMO a higher quality product than the new torx ones. Much easier to engage from more angles and would hold on in place on the bit better to allow one hand use.
I don't build decks but do use them for all kinds of maintenance/repair work, keep a box of every size of the ACR's on the truck, don't think I've ever broke one of those blue tip bits. You'd know why if you compared them to the little spindly torx bit, which I have broke those already, even with little use.
http://www.phillips-screw.com/Comm_Auto_acr_phillipsII.htm
JB.
   / Screw Head Bits #27
What I have found is that most stripping of screw heads when using a phillips head is from not holding the drill bit perfectly perpindicular to the screw. That is assuming that you have the correct size bit for the screw. If you have the bit even slightly angled, it will tend to push itself out and start to spin in the screw head. Just a few rotations will completely round out a phillips head. DO this several times and your bit is toast. I dont think I have ever stripped a Robertson, I've twisted off a bunch of the longer ones in hardwood before they got tight, but never stripped the head. I usually just buy the old Black and Decker package from Walmart or the Sears Craftsman. I find that they work just about as well as any when used properly.
   / Screw Head Bits #28
After trying Robertson (square head) screws, I am sold on them. McFeely's has a set of Canadian made screwdrivers with fat black handles that are comfortable to use, and are made well. I also bought a couple of Klein stubby drivers and am happy with them too.
All the DeWalt bit's I've bought are pure crap; but the McFeely's bits are good quality.
TORX are common in the auto industry and I should use them on my tractor projects.
As for slotted and Phillips screws...I throw them out, unless they are my only choice.
   / Screw Head Bits #29
Well, I guess that I am not to old to learn new stuff. I believe that I have been mixing the different types of screw bits whenever I work on something. Never thinking that the bits for hand screw drivers were that much different. I have used the blue bits in each pkg of screws, but usually I grab the first bit I can find. The insert bits are the lowest grade of bits available, then you have the power bits, torsion bits, TORX bits, TORX tamper proof, LOX bits, which have 8 grab points. clutch bits,spanner bits. etc, and the break down goes on and on. Irwin's web site shows most of the bits available.
IRWIN Fastener Drive
IRWIN TORQ-SET® Power Bits
Look at all the bits under power bits.
   / Screw Head Bits #30
SteelDust,
I have a couple of boxes of the Torx head Deckmates out in my barn, this weekend I'll grab a picture or two.
On my barn project, I used Spax stainless screws to secure all of the trim work and as fasteners on the doors. I don't think I've ever had a screw that drove as easily as the Spax, the first few threads were serrated and they grabbed and drove very fast. I did strip the head out of a couple of them though, more my fault, as mentioned the most important thing is keeping the drive bit and the screw head aligned. The Spax screws that I used had a square drive. I will put up some pictures of those as well.
I'm getting a kick out of this. Some how I've found DeckMates that are Torx and Spax that are square drive while others here are finding different. I wonder if it's a regional thing?
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2005 Greatdane Trailer (A52377)
2005 Greatdane...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
