dynasim
Schlen,
I think you are probably the highest hour HST guy that I have seen. Could you take a picture of your tractor, and post it?
Does your tractor hold its position when the pedal is centered, and it is on a hill? That would be a good way to tell if there is a leakage problem. On mine, which is one bigger in frame size, on a 1/12 slope hill, it'll move about 1 foot per minute. I would expect that mine will increase in speed(leakage) as time goes by. They are designed for some amount of leak through, so perfect is not zero leakage.
Also, are you sure your clutch is good? I think your model has one, and even if it has an HST, it may very well have finally worn out.
Can you kill the engine by pushing the pedal in all the way. If you can't, and you don't have leakage, or a worn clutch, it is likely that you have a bypass issue, in my opinion, and it would be worth it to check it out. Keep in mind, though, that your 33 is at the upper end of the class size(I think), and therefore, is operating at the limit of the transmission design.
I don't have your same frame size, but I would never characterize my HST as non-responsive. It will give one whiplash if you stop to fast.
Possibly you could go test drive a 33 or 34 at a dealer to get a comparison.
Again, congratulations, and I hope it lasts another 5100 hours.
Chris
Chris
