When was my L3010 built?
   / When was my L3010 built? #1
moot
Member
Georgia
Kubota L3010
Is there a way to find out when my L3010 was built?
Is there a 'decode' for the Serial Number?
Well, I finally found the Engine Serial. I expected it to be stamped into the block -but no- it is just a tab on the injection pump gasket, covered by gasket sealant. After spraying some Blaster on it and careful sanding with emery cloth I could see the alpha-numeric.
D1503-LAN1945
I went to Kubota Engine America - Compact Diesel Engines to id the model.
D = Cylinder Code for 3 CYL
15 = Displacement of 1500cc
03 = Kubota 03 Series
Makes sense...so far...
Now I went to Kubota Engine America - Compact Diesel Engines to get the serial number identification. This is were it gets confusing...
Old Format
. 4-6 numbers that are sequential with no breaks for production month or year
New Format (starting 1997)
. Alpha-numeric (e.g. XJ5050 or 4J5050) with breaks for production month and year
FIRST DIGIT = PRODUCTION YEAR
SECOND DIGIT = PRODUCTION MONTH
-LAN1945 makes no sense - to me anyway. Any way I juggle the alpha-numeric I cannot get anything reasonable. I cannot believe my unit was built before 1997 - could it? Anyway they don't document the 'Old Format'...
If anyone can help I'd appreciate it...
Thanks. I found that maybe the mfg for the L3010GST was from 1998-2001.
Guess that will have to do. I did send an email to Kubota to see if I could narrow it down more. I'm putting it up for sale and like to have as much accurate info as possible.
Still interested if anyone has a clue on what's up with the serial # decode.
-LAN1945 makes no sense ...
If I turn the -LA into a W then it may... W=1998 N=Jul
It surprises me that it has such low hours (265)... should I be suspicious?
   / When was my L3010 built? #6
Check the wheels to see if there is a date stamped into the wheel --- that will be the best "Date of Manufacture" that I know of ---------
   / When was my L3010 built? #7
My parts manual explain the codes for my L4330. They don't match your numbers but you might find the manual for your model on line and get the numbers explained.
2016 Ford F-550 Palfinger PSC3216 4,000LB Crane Service Truck (A51692)
2016 Ford F-550...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
