Lincoln 225 AC/DC Welder Comments?
   / Lincoln 225 AC/DC Welder Comments? #11
I have a lincoln 225 AC only. Took a boces course which helped. Does a fine job for my type of welding which is farm welding. DC runs a nicer bead but there are different type rods even for ac that are easy to use. 6013 runs a pretty good bead on clean metal, 6011 burns thru anything but a lot of splatter. Buy your rod at a welding supply store and pick the guys brains. My store steered me to some 80000 lb tesnile strength stuff that runs a really nice bead. I never would have found that in a TSC or home depot. I also bought a small mig which is very nice for small projects and tacking things together. Not a hard skill but there are a LOT of variables that are hard to learn unless you do it every day. Anyone who tells you they know everything about welding either doesn't know much or I'd like to meet!
   / Lincoln 225 AC/DC Welder Comments? #12
"Lot of variables in welding" ---that is the truth.
One useful feature of DC is you can stick weld aluminum. Have used it only a couple of times, but saved myself some bucks by repairing some parts instead of having to buy new ones.
   / Lincoln 225 AC/DC Welder Comments? #13
Pretty useful feature and another reason to get DC. Wish I had. There were a few occasions I had the need but not the equipment!! I always thought you had to tig aluminum - probably should have sprung for the ac/dc!!
   / Lincoln 225 AC/DC Welder Comments? #14
Thats a great deal on a ac/dc 225 lincoln.I paid about $430 for mine 5 years ago and that was the lowest i could find then.
Also,with D/C ,you can hook up a scratch start tig for steel & stainless only,or if you want to go high tech,you can get a high freq. box and do aluminum.The catch is,by the time you buy the machine and the high freq. box,your running into some serious $$$ and you might as well buy a high freq. equipped machine to begin with.If you wanted to do that stuff (tig).And you would have to watch the duty cycle,if you went that route.But,you are interested in stick welding.
But really,for stick welding and for the money,you cant beat them.And they do seem to last forever.My Dad had one for about 40 years and the only thing that went bad was the on/off switch.....go get it.:D.......Digger2
   / Lincoln 225 AC/DC Welder Comments? #15
GOT 1 ORDERED
THANKS FOR A CHEAP DEAL
I HAVE WORE 1 OF THESE OUT SO THEY DO BREAK THE COILS....
AND I HAVE NOT FOUND A DC ..LOTS OF AC ON THE LIST THANKS!:D
WoodRR- I probably shouldn't have gotten all you folks 'wired-up' on this deal until I had mine ordered, and in hand for that price. My friend's suppose to be putting in the order tonight, so I'll know more tomorrow. Curious, Wood Man, did they 'do the deal' as I described? IE They 'eat' the shipment to their store? You did order the AC/DC model correct? Thanks to all of you that offered your great input! Scotty
   / Lincoln 225 AC/DC Welder Comments? #17
I just saw your post and hope you enjoy your AC/DC Machine. As one fellow member advised, using Craigslist can get you some good deals if you keep yourself advised of new prices. I picked up a slightly used good as new Miller 350 Amp AC/DC Constant Current (CC- this means it will run a wire feed gun also) with 70% duty cycle with 100 feet of 2/0 welding lead and 50 feet of ground lead for $350. I got it from a fabshop that was downsizing due to the economy and he was getting rid of it because he hardly ever used it. It works great. I had the guy demo it before I bought it just to make sure. I am proud of that purchase and lucky to be there first to pick it up at that price. Craigslist has some good bargains, but not always. I have seen folks list welding machines for prices more than you can find it new so you do have to be a wise shopper. I have been in the heavy industrial construction business for 40 years starting out as a welder using Miller machines like this and they have the smoothest most stable arc of any machine that I have ever used which is why I was so eager to buy this one.
Oh yeah at 70 amps on the dial, it will smoothly run a 1/8" E-7018 rod so I dont think I will every have to worry about overheating this unit. It would easily handle 3/16" diameter rods but I have not intention of ever welding something that would require that size electrode.
   / Lincoln 225 AC/DC Welder Comments? #18
I picked up a hobart stickmate XL 235 AC machine a couple years ago.. got it at TSC.. was 20$ cheaper than the AC 225 lincoln machine at lowes/HD.
Been a great basic machine. it runs up to 100A at 100% duty cycle and has a good dial/crank amps gauge, vs the knob selector.
I've welded up to 1/2" with ease.. and 3/4 stuff with plenty of prep.
If you plan on doing alot of welding get DC.. if yuo want to do occasional farm welding on a budget.. a big honkin AC machine should get you done with some 6011 rod.. if it has to look perty.. hit it with a top coat of 6013.. as keep a 4" angle grinder and a slag hammer nearby with your gloves, face mask and wire brush and you are set.
remember.. miller owns hobart..
soundguy
I'm about to 'pull the trigger' on a stick welder purchase. I want to stay with one of the big players in the welding game ie, Lincoln, Miller, Hobart, etc. Guess with all the history that the old "Tombstone Lincoln" has, I'm sort of leaning that way. The DC is a plus (I guess) over the old boxes. I'm fairly proficient with Oxy/Ace cutting and welding on thinner materials, so I've got the basics down about what it takes to 'glue' two pieces of metal together, but other than toying with my son's wire Mig machine, I've never 'struck-an-arc'. I'm not wild about buying over the net, as I'd rather support local business, but surfing has shown the K-1297 between $490.'s to over $600 bucks! I stumbled across the same unit on the web advertised by Home Depot for $389.-!! OK, add to cart, viola! Add $200. Shipping!! Bummer! Speaking with a friend that works PT at HD, he called his boss who said "No problem" They'd just special order it in, and sell it to me for $389.- (plus my local sales tax). This was NOT because my friend works there, just something they'd do!! I'm ready go with it.
Now a couple questions! Are DC worth the extra money? Can a person get relitively proficient stick welding, in a reasonable amount of time? I envision 1/4-3/8" steel will be the bulk of my challanges. Does this sound like a unit that a 'newby' to the art of electric arc would be well served with? Any comment on price/value are appreciated. Thanks in advance. ~Scotty
   / Lincoln 225 AC/DC Welder Comments? #19
I picked up an old Hobart stick machine (AC only) for cheap money about twenty years ago. It works well.
However.
If I was in the market for a new welder I would certainly want to have the DC capability.
There is better availability of electrodes to weld a greater variety of alloys.
You'll find that the weld puddle is more predictable with DC (I have used DC, I just don't own a machine) and as a result, the quality of your results will improve.
Just a quick update! I did get it at that ($389-) price! Funny thing was, when I went to pick it up, they wheeled out a pallet with two of them on it, both with my name! Tryed to tell the gal that they must be having a two-for-one special, but she wasn't buying it!!
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2007 FORD F-450 (A50854)
2007 FORD F-450...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
